99-3383-100-04
99-3383-100-04
    BINDER(宾德)
99-3383-100-04 数据手册
Product data sheet Automation technology - sensors and actuators Product description M8 cable connector, Contacts: 4, 3.5 - 5.0 mm, not shielded, screw clamp, IP67, UL listed Area Order number M8 series 768 99 3383 100 04 Illustration Scale drawing Contact arrangement You can find the component part drawing and assembly instructions on the next page. Technical data General values Connector design Connector locking system Termination Wire gauge (mm) Wire gauge (AWG) Cable outlet Upper limit temperature Lower limit temperature Customs tariff number Packaging Unit Electrical values cable connector screw screw clamp 0.14 - 0.50 mm² 26 - 20 3.5 - 5.0 mm 85 °C – 40 °C 85369010 100 4A 60 V 1500 V 3 III III not shielded IP67 > 100 Mating cycles Material Cable data Approval 1 Rated current (40 °C) Rated voltage Rated impulse voltage Pollution degree Overvoltage category Insulating material group EMC compliance Degree of protection Mechanical operation UL listed Contact material Contact plating Contact body material Housing material CuZn (brass) Au (gold) PA PA Date: 2020-01-19 - Page 1 of 3 Product data sheet Automation technology - sensors and actuators Product description M8 cable connector, Contacts: 4, 3.5 - 5.0 mm, not shielded, screw clamp, IP67, UL listed Area Order number M8 series 768 99 3383 100 04 Component part drawing Assembly instructions / Panel cut-out Date: 2020-01-19 - Page 2 of 3 Powered by TCPDF (www.tcpdf.org) Product data sheet Automation technology - sensors and actuators Product description M8 cable connector, Contacts: 4, 3.5 - 5.0 mm, not shielded, screw clamp, IP67, UL listed Area Order number M8 series 768 99 3383 100 04 Security notices The connectors are designed for use in plant, control system and electrical equipment. The end user is responsible for checking whether the connectors are suitable for use in other applications. Connectors with degree of protection IP 67 and IP 68 are not suitable for use under water. When used outdoors, the connectors must be separately protected against corrosion. For further information about IP degrees of protection refer to ‘Technical support’ in the Download Centre. To lock the cable connector to the equipment connector, the threaded ring is tightened until it is ‘finger-tight’ (approx. 50 cNm). Date: 2020-01-19 - Page 3 of 3
99-3383-100-04 价格&库存
很抱歉,暂时无法提供与“99-3383-100-04”相匹配的价格&库存,您可以联系我们找货
  • 1+136.29630
  • 10+133.29712
  • 50+130.17297
  • 100+126.75723
  • 250+123.75804
库存:38
