99-6518-000-12
99-6518-000-12
    BINDER(宾德)
    BINDER - 99-6518-000-12 - Circular Connector, 26-18AWG, HEC 696 Series, Cable Mount Receptacle, 12 C...
99-6518-000-12 数据手册
Product sheet power connector Product contacts 12: female cable connector, cable outlet 6-13mm Area Article number Bajonett HEC Power Series 696 99 6518 000 12 Illustration Scale drawing Contact Arrangement You can find the item description and assembly instruction on the next page. Technical data Common values Connector Design Connector locking system Termination Wire gauge (mm) Wire gauge (AWG) Cable outlet Upper temperature Lower temperature Electrical values Female cable connector Bayonet Crimp 0.14 –0.75 mm² 26–18 6 - 13mm 100 °C -40 °C Rated voltage Rated impulse voltage Pollution degree Overvoltage category Material group Rated current (40°C) Volume resistivity Degree of protection Mechanical operation 250 V 5000 V 3 III I,II 5A ≤ 8 mΩ IP68/IP69K > 1000 mating cycles Material Contact plating Material of contact body Material of housing Au (Gold) PA PA Date: 2016-01-14 - Page 1 of 3 Product sheet power connector Product contacts 12: female cable connector, cable outlet 6-13mm Area Article number Bajonett HEC Power Series 696 99 6518 000 12 Item description Installation instructions / Mounting cutout Date: 2016-01-14 - Page 2 of 3 Powered by TCPDF (www.tcpdf.org) Product sheet power connector Product contacts 12: female cable connector, cable outlet 6-13mm Area Article number Bajonett HEC Power Series 696 99 6518 000 12 Installation instructions / Mounting cutout Date: 2016-01-14 - Page 3 of 3
99-6518-000-12 价格&库存
很抱歉,暂时无法提供与“99-6518-000-12”相匹配的价格&库存,您可以联系我们找货
