01-0013-001
01-0013-001
    BINDER(宾德)
    BINDER - 01-0013-001 - Connector Accessory, Hex Nut, Binder 712/702 Series Circular Connectors, 712/...
01-0013-001 数据手册
Accessory data sheet Product description Knurled hexagonal nut, 2 mm Order number 01 0013 001 Illustration Technical data Wrench size SW14 Matching products 09 0403 00 02 - Male panel mount connector, solder 09 0403 30 02 - Male panel mount connector, dip-solder, screwed from front with shielding sheet (6 mm) 09 0403 35 02 - Male panel mount connector, dip-solder, screwed from front with shielding sheet (10 mm) 09 0403 80 02 - Male panel mount connector, solder, screwed from front 09 0403 90 02 - Male panel mount connector, dip-solder, screwed from front 09 0404 00 02 - Female panel mount connector, solder 09 0404 30 02 - Female panel mount connector, dip-solder, screwed from front with shielding sheet (6 mm) 09 0404 35 02 - Female panel mount connector, dip-solder, screwed from front with shielding sheet (10 mm) 09 0404 55 02 - Female panel mount connector, dip-solder, screwed from front with shielding sheet, angled 09 0404 80 02 - Female panel mount connector, solder, screwed from front 09 0404 90 02 - Female panel mount connector, dip-solder, screwed from front 09 0407 00 03 - Male panel mount connector, solder 09 0407 30 03 - Male panel mount connector, dip-solder, screwed from front with shielding sheet (6 mm) 09 0407 35 03 - Male panel mount connector, dip-solder, screwed from front with shielding sheet (10 mm) 09 0407 80 03 - Male panel mount connector, solder, screwed from front 09 0407 90 03 - Male panel mount connector, dip-solder, screwed from front 09 0408 00 03 - Female panel mount connector, solder 09 0408 30 03 - Female panel mount connector, dip-solder, screwed from front with shielding sheet (6 mm) 09 0408 35 03 - Female panel mount connector, dip-solder, screwed from front with shielding sheet (10 mm) 09 0408 80 03 - Female panel mount connector, solder, screwed from front 09 0408 90 03 - Female panel mount connector, dip-solder, screwed from front 09 0411 00 04 - Male panel mount connector, solder 09 0411 30 04 - Male panel mount connector, dip-solder, screwed from front with shielding sheet (6 mm) 09 0411 35 04 - Male panel mount connector, dip-solder, screwed from front with shielding sheet (10 mm) 09 0411 80 04 - Male panel mount connector, solder, screwed from front 09 0411 90 04 - Male panel mount connector, dip-solder, screwed from front 09 0412 00 04 - Female panel mount connector, solder 09 0412 30 04 - Female panel mount connector, dip-solder, screwed from front with shielding sheet (6 mm) 09 0412 35 04 - Female panel mount connector, dip-solder, screwed from front with shielding sheet (10 mm) 09 0412 80 04 - Female panel mount connector, solder, screwed from front 09 0412 90 04 - Female panel mount connector, dip-solder, screwed from front 09 0415 00 05 - Male panel mount connector, solder 09 0415 30 05 - Male panel mount connector, dip-solder, screwed from front with shielding sheet (6 mm) 09 0415 35 05 - Male panel mount connector, dip-solder, screwed from front with shielding sheet (10 mm) Date: 2019-11-03 - Page 1 of 2 Powered by TCPDF (www.tcpdf.org) Accessory data sheet Product description Knurled hexagonal nut, 2 mm Order number 01 0013 001 09 0415 80 05 - Male panel mount connector, solder, screwed from front 09 0415 90 05 - Male panel mount connector, dip-solder, screwed from front 09 0416 00 05 - Female panel mount connector, solder 09 0416 30 05 - Female panel mount connector, dip-solder, screwed from front with shielding sheet (6 mm) 09 0416 35 05 - Female panel mount connector, dip-solder, screwed from front with shielding sheet (10 mm) 09 0416 55 05 - Female panel mount connector, dip-solder, screwed from front with shielding sheet, angled 09 0416 80 05 - Female panel mount connector, solder, screwed from front 09 0416 90 05 - Female panel mount connector, dip-solder, screwed from front 09 0423 00 07 - Male panel mount connector, solder 09 0423 30 07 - Male panel mount connector, dip-solder, screwed from front with shielding sheet (6 mm) 09 0423 35 07 - Male panel mount connector, dip-solder, screwed from front with shielding sheet (10 mm) 09 0423 65 07 - Male panel mount connector with flexible printed circuit board (PCB) 09 0423 80 07 - Male panel mount connector, solder, screwed from front 09 0423 90 07 - Male panel mount connector, dip-solder, screwed from front 09 0424 00 07 - Female panel mount connector, solder 09 0424 30 07 - Female panel mount connector, dip-solder, screwed from front with shielding sheet (6 mm) 09 0424 35 07 - Female panel mount connector, dip-solder, screwed from front with shielding sheet (10 mm) 09 0424 65 07 - Female panel mount connector with flexible printed circuit board (PCB) 09 0424 80 07 - Female panel mount connector, solder, screwed from front 09 0424 90 07 - Female panel mount connector, dip-solder, screwed from front 09 0427 00 08 - Male panel mount connector, solder 09 0427 30 08 - Male panel mount connector, dip-solder, screwed from front with shielding sheet (6 mm) 09 0427 35 08 - Male panel mount connector, dip-solder, screwed from front with shielding sheet (10 mm) 09 0427 65 08 - Male panel mount connector with flexible printed circuit board (PCB) 09 0427 80 08 - Male panel mount connector, solder, screwed from front 09 0427 90 08 - Male panel mount connector, dip-solder, screwed from front 09 0428 00 08 - Female panel mount connector, solder 09 0428 30 08 - Female panel mount connector, dip-solder, screwed from front with shielding sheet (6 mm) 09 0428 35 08 - Female panel mount connector, dip-solder, screwed from front with shielding sheet (10 mm) 09 0428 65 08 - Female panel mount connector with flexible printed circuit board (PCB), contacts 8 09 0428 80 08 - Female panel mount connector, solder, screwed from front 09 0428 90 08 - Female panel mount connector, dip-solder, screwed from front Date: 2019-11-03 - Page 2 of 2
01-0013-001 价格&库存
很抱歉,暂时无法提供与“01-0013-001”相匹配的价格&库存,您可以联系我们找货
