08-2676-000-000
08-2676-000-000
    BINDER(宾德)
08-2676-000-000 数据手册
Accessory data sheet Product description Protection cap for male panel mount connector Order number 08 2676 000 000 Illustration Technical data Degree of protection IP67 Matching products 09 0381 81 08 - Male panel mount connector, fixing thread, M12 x 0.5 09 0431 16 04 - Square Male panel mount connector, adjustable, Optimal contact plating, IP 40, with seal IP 67 (see accessories) 09 0431 212 04 - Male panel mount connector with metal threaded sheath 09 0431 397 04 - Male panel mount connector, metric fixing thread, adjustable 09 0431 81 04 - Male panel mount connector, fixing thread, M12 x 0.5 09 0433 16 05 - Square Male panel mount connector, adjustable, Optimal contact plating, IP 40, with seal IP 67 (see accessories) 09 0433 81 05 - Male panel mount connector, fixing thread, M12 x 0.5 09 0435 87 04 - Male panel mount connector, fixing thread, PG 11 09 0437 87 05 - Male panel mount connector, fixing thread, PG 11 09 0439 397 04 - Male panel mount connector, metric fixing thread, adjustable 70 3441 287 05 - Male panel mount connector, PG 9, screwed from front, with shielded PUR cable 70 3441 785 05 - Male panel mount connector M 16, with shielded PUR cable 70 3481 287 08 - Male panel mount connector, PG 9, screwed from front, with shielded PUR cable 70 3481 785 08 - Male panel mount connector M 16, with shielded PUR cable 70 3733 705 04 - Male panel mount connector M16, with PROFINET cable, shielded 70 3733 706 04 - Male panel mount connector, PG 9, screwed from front, with PROFINET cable, shielded 70 4433 246 04 - Male panel mount connector M16, with PROFIBUS cable, shielded 76 0131 0011 00004-0200 - Male panel mount connector with single wires, 0.25 mm², PG 9, M16 x 1.5, PG 9 stainless steel, M16 x 1.5 VA 76 0131 0011 00005-0200 - Male panel mount connector with single wires, 0.25 mm², PG 9, M16 x 1.5, PG 9 stainless steel, M16 x 1.5 VA 76 0231 0011 00008-0200 - Male panel mount connector with single wires, 0.25 mm², PG 9, M16 x 1.5, PG 9 stainless steel, M16 x 1.5 VA 76 0331 0111 00004-0200 - Male panel mount connector with single wires 0.25 mm², metal housing with fixing thread M20 x 1.5 and PG 13.5 76 0331 0111 00005-0200 - Male panel mount connector with single wires 0.25 mm², metal housing with fixing thread M20 x 1.5 and PG 13.5 76 0331 0111 00008-0200 - Male panel mount connector with single wires 0.25 mm², metal housing with fixing thread M20 x 1.5 and PG 13.5 76 0331 0111 00012-0200 - Male panel mount connector with single wires 0.25 mm², metal housing with fixing thread M20 x 1.5 and PG 13.5 76 0431 0111 00004-0200 - Male panel mount connector with single wires 0.25 mm², metal housing with fixing thread M20 x 1.5 and PG 13.5 76 0431 0111 00005-0200 - Male panel mount connector with single wires 0.25 mm², metal housing with fixing thread M20 x 1.5 and PG 13.5 76 0531 1011 00004-0200 - Male panel mount connector with single wires, screwed from front, 0.25 mm², PG 9, M16 x 1.5, PG 9 stainless steel 76 0531 1011 00005-0200 - Male panel mount connector with single wires, screwed from front, 0.25 mm², PG 9, M16 x 1.5, PG 9 stainless steel 76 0533 1011 00104-0200 - Male panel mount connector, screwed from front, with single wires 0.25 mm² 76 0533 1011 00105-0200 - Male panel mount connector, screwed from front, with single wires 0.25 mm² 76 0631 1011 00004-0200 - Male panel mount connector with single wires, screwed from front, 0.25 mm², PG 9, M16 x 1.5, PG 9 stainless steel 76 0631 1011 00005-0200 - Male panel mount connector with single wires, screwed from front, 0.25 mm², PG 9, M16 x 1.5, PG 9 stainless steel 76 0631 1011 00008-0200 - Male panel mount connector with single wires, screwed from front, 0.25 mm², PG 9, M16 x 1.5, PG 9 stainless steel 76 0631 1111 00012-0200 - Male panel mount connector with single wires, screwed from front, 0.25 mm², PG 9, M16 x 1.5, PG 9 stainless steel Date: 2019-11-03 - Page 1 of 3 Accessory data sheet Product description Protection cap for male panel mount connector Order number 08 2676 000 000 76 0731 0011 00004-0200 - Male panel mount connector, adjustable, with single wires, 0.25 mm², PG 9, M16 x 1.5, PG 9 stainless steel 76 0731 0011 00005-0200 - Male panel mount connector, adjustable, with single wires, 0.25 mm², PG 9, M16 x 1.5, PG 9 stainless steel 76 0831 0011 00004-0200 - Male panel mount connector, adjustable, with single wires, 0.25 mm², PG 9, M16 x 1.5, PG 9 stainless steel 76 0831 0011 00005-0200 - Male panel mount connector, adjustable, with single wires, 0.25 mm², PG 9, M16 x 1.5, PG 9 stainless steel 76 0831 0011 00008-0200 - Male panel mount connector, adjustable, with single wires, 0.25 mm², PG 9, M16 x 1.5, PG 9 stainless steel 76 0831 0111 00012-0200 - Male panel mount connector, adjustable, with single wires, 0.25 mm², PG 9, M16 x 1.5, PG 9 stainless steel 76 0931 0111 00004-0200 - Male socket, Degree of protec. Without sealing IP 40, with sealing IP 67 (see accessories) 76 0931 0111 00005-0200 - Male socket, Degree of protec. Without sealing IP 40, with sealing IP 67 (see accessories) 76 2131 0111 00004-0200 - Male panel mount connector with single wires, 0.25 mm², PG 9, M16 x 1.5, PG 9 stainless steel, M16 x 1.5 VA 76 2131 0111 00005-0200 - Male panel mount connector with single wires, 0.25 mm², PG 9, M16 x 1.5, PG 9 stainless steel, M16 x 1.5 VA 76 2231 0111 00004-0200 - Male panel mount connector with single wires, 0.25 mm², PG 9, M16 x 1.5, PG 9 stainless steel, M16 x 1.5 VA 76 2231 0111 00005-0200 - Male panel mount connector with single wires, 0.25 mm², PG 9, M16 x 1.5, PG 9 stainless steel, M16 x 1.5 VA 76 2531 1111 00005-0200 - Male panel mount connector with single wires, screwed from front, 0.25 mm², PG 9, M16 x 1.5, PG 9 stainless steel 76 2531 1111 00008-0200 - Male panel mount connector with single wires, screwed from front, 0.25 mm², PG 9, M16 x 1.5, PG 9 stainless steel 76 2731 0111 00004-0200 - Male panel mount connector, adjustable, with single wires, 0.25 mm², PG 9, M16 x 1.5, PG 9 stainless steel 76 2731 0111 00005-0200 - Male panel mount connector, adjustable, with single wires, 0.25 mm², PG 9, M16 x 1.5, PG 9 stainless steel 76 2731 0111 00008-0200 - Male panel mount connector, adjustable, with single wires, 0.25 mm², PG 9, M16 x 1.5, PG 9 stainless steel 76 2831 0111 00004-0200 - Male panel mount connector, adjustable, with single wires, 0.25 mm², PG 9, M16 x 1.5, PG 9 stainless steel 76 2831 0111 00005-0200 - Male panel mount connector, adjustable, with single wires, 0.25 mm², PG 9, M16 x 1.5, PG 9 stainless steel 76 2831 0111 00008-0200 - Male panel mount connector, adjustable, with single wires, 0.25 mm², PG 9, M16 x 1.5, PG 9 stainless steel 86 0131 0000 00004 - Male panel mount connector, dip-solder 86 0131 0000 00005 - Male panel mount connector, dip-solder 86 0131 0000 00008 - Male panel mount connector, dip-solder 86 0131 0000 00012 - Male panel mount connector, dip-solder 86 0131 0002 00004 - Male panel mount connector, solder, metal, PG 9, M16 x 1.5 86 0131 0002 00005 - Male panel mount connector, solder, metal, PG 9, M16 x 1.5 86 0131 0002 00008 - Male panel mount connector, solder, metal, PG 9, M16 x 1.5 86 0231 0000 00004 - Male panel mount connector, dip-solder 86 0231 0000 00005 - Male panel mount connector, dip-solder 86 0231 0000 00008 - Male panel mount connector, dip-solder 86 0231 0000 00012 - Male panel mount connector, dip-solder 86 0231 0002 00004 - Male panel mount connector, solder, metal, PG 9, M16 x 1.5 86 0231 0002 00005 - Male panel mount connector, solder, metal, PG 9, M16 x 1.5 86 0231 0002 00008 - Male panel mount connector, solder, metal, PG 9, M16 x 1.5 86 0531 1000 00004 - Male panel mount connector, screwed from front, dip-soldered, PG 9 86 0531 1000 00005 - Male panel mount connector, screwed from front, dip-soldered, PG 9 86 0531 1000 00008 - Male panel mount connector, screwed from front, dip-soldered, PG 9 86 0531 1002 00004 - Male panel mount connector, front fastened, solder, metal housing 86 0531 1002 00005 - Male panel mount connector, front fastened, solder, metal housing 86 0531 1002 00008 - Male panel mount connector, front fastened, solder, metal housing 86 0531 1100 00012 - Male panel mount connector, screwed from front, dip-soldered, PG 9 86 0531 1120 00004 - Male panel mount connector, screwed from front, with shielding sheet, dip-soldered, PG 9 86 0531 1120 00005 - Male panel mount connector, screwed from front, with shielding sheet, dip-soldered, PG 9 86 0531 1120 00008 - Male panel mount connector, screwed from front, with shielding sheet, dip-soldered, PG 9 86 0531 1120 00012 - Male panel mount connector, screwed from front, with shielding sheet, dip-soldered, PG 9 86 0631 1000 00004 - Male panel mount connector, screwed from front, dip-soldered, PG 9 86 0631 1000 00005 - Male panel mount connector, screwed from front, dip-soldered, PG 9 86 0631 1000 00008 - Male panel mount connector, screwed from front, dip-soldered, PG 9 86 0631 1002 00004 - Male panel mount connector, front fastened, solder, metal housing 86 0631 1002 00005 - Male panel mount connector, front fastened, solder, metal housing 86 0631 1002 00008 - Male panel mount connector, front fastened, solder, metal housing 86 0631 1100 00012 - Male panel mount connector, screwed from front, dip-soldered, PG 9 86 1031 1100 00004 - Male panel mount connector, screwed from front, dip-soldered, M12 x 1, 10.5 mm contact length 86 1031 1100 00005 - Male panel mount connector, screwed from front, dip-soldered, M12 x 1, 10.5 mm contact length 86 1031 1100 00008 - Male panel mount connector, screwed from front, dip-soldered, M12 x 1, 10.5 mm contact length 86 1031 1100 00012 - Male panel mount connector, screwed from front, dip-soldered, M12 x 1, 10.5 mm contact length 86 2531 1100 00005 - Male panel mount connector, screwed from front, dip-soldered, PG 9 86 2531 1100 00008 - Male panel mount connector, screwed from front, dip-soldered, PG 9 86 4231 1002 00004 - Male panel mount connector, fixing thread, PG 9, M16 x 1.5 86 4231 1002 00005 - Male panel mount connector, fixing thread, PG 9, M16 x 1.5 86 4231 1002 00008 - Male panel mount connector, fixing thread, PG 9, M16 x 1.5 86 4233 1002 00004 - Male panel mount connector, fixing thread, PG 9, M16 x 1.5 86 4331 1002 00004 - Male panel mount connector, fixing thread, PG 9, M16 x 1.5 86 4331 1002 00005 - Male panel mount connector, fixing thread, PG 9, M16 x 1.5 86 4331 1002 00008 - Male panel mount connector, fixing thread, PG 9, M16 x 1.5 86 4333 1002 00004 - Male panel mount connector, fixing thread, PG 9, M16 x 1.5 86 4333 1002 00005 - Male panel mount connector, fixing thread, PG 9, M16 x 1.5 86 4531 1002 00004 - Male panel mount connector, fixing thread, PG 13.5, M20 x 1.5 86 4531 1002 00005 - Male panel mount connector, fixing thread, PG 13.5, M20 x 1.5 86 4631 1002 00004 - Male panel mount connector, fixing thread, PG 13.5, M20 x 1.5 Date: 2019-11-03 - Page 2 of 3 Powered by TCPDF (www.tcpdf.org) Accessory data sheet Product description Protection cap for male panel mount connector Order number 08 2676 000 000 86 4631 1002 00005 - Male panel mount connector, fixing thread, PG 13.5, M20 x 1.5 99 3431 200 04 - Integrated plug for PCB mounting, straight, UL approval 99 3431 202 04 - Integrated plug for PCB mounting, angled, UL approval 99 3431 458 04 - Integrated plug for PCB mounting, straight, UL approval 99 3431 601 04 - Integrated plug for PCB mounting, angled, UL approval 99 3433 100 04 - Male socket, Degree of protec. Without sealing IP 40, with sealing IP 67 (see accessories) 99 3441 200 05 - Integrated plug for PCB mounting, straight, UL approval 99 3441 202 05 - Integrated plug for PCB mounting, angled, UL approval 99 3441 458 05 - Integrated plug for PCB mounting, straight, UL approval 99 3441 601 05 - Integrated plug for PCB mounting, angled, UL approval 99 3443 100 05 - Male socket, Degree of protec. Without sealing IP 40, with sealing IP 67 (see accessories) 99 3481 200 08 - Integrated plug for PCB mounting, straight, UL approval 99 3481 202 08 - Integrated plug for PCB mounting, angled, UL approval 99 3481 458 08 - Integrated plug for PCB mounting, straight, UL approval 99 3481 601 08 - Integrated plug for PCB mounting, angled, UL approval 99 3731 200 04 - Integrated plug for PCB mounting, straight, UL approval 99 3731 201 04 - Integrated plug for PCB mounting, straight, UL approval 99 3731 202 04 - Integrated plug for PCB mounting, angled, UL approval 99 3731 203 04 - Integrated plug for PCB mounting, angled, UL approval 99 4445 200 05 - Integrated plug for PCB mounting, straight, UL approval 99 4445 202 05 - Integrated plug for PCB mounting, angled, UL approval 99 4445 458 05 - Integrated plug for PCB mounting, straight, UL approval 99 4445 601 05 - Integrated plug for PCB mounting, angled, UL approval Date: 2019-11-03 - Page 3 of 3
08-2676-000-000 价格&库存
很抱歉,暂时无法提供与“08-2676-000-000”相匹配的价格&库存,您可以联系我们找货
    • 1+51.81683
    • 50+51.44551
    • 100+50.75079
    • 250+50.51123
    • 1250+41.32410
    库存:94
