09 0330 00 12
09 0330 00 12
    BINDER(宾德)
    BINDER - 09 0330 00 12 - Circular Connector, 680 Series, Cable Mount Plug, 12 Contacts, Solder Socke...
09 0330 00 12 数据手册
Product sheet Miniature connectors Female cable connector, cable outlet 3-6 mm M16 connectors IP 40 illustration Pole Article number serie 680 scale drawing Date: 2013-10-02 - Page 1 of 2 Product Area 12 09 0330 00 12 Contact Arrangement You can find the item description on the next page. Technical data Common values Material Connector Design Female cable connector Connector locking system Screw-locking Termination solder Wire gauge (mm) 0,25 mm² Wire gauge (AWG) 24 Max. Cable outlet 3 - 6 mm Upper temperature +85 °C Lower temperature -40 °C Material of contact CuSn (bronce) Contact plating Au (gold) Material of contact body PBT (UL 94 V-0) Material of housing PA (UL 94 HB) Cable data Contacts 12, female cable connector, cable outlet 3 – 6 mm, gold plated contacts Electrical values Rated voltage 60 V Rated impulse voltage 500 V Pollution degree 1 Overvoltage category I Material group III Rated current (40°C) 3A Volume resistivity ≤ 3 mΩ EMV compliance not shielded Degree of protection IP 40 Mechanical operation >500 mating cycles Normen und Prüfbedingungen siehe Binder Katalog Seite T1-16 oder unter www.binder-connector.de 09 0330 00 12 Product sheet Miniature connectors Female cable connector, cable outlet 3-6 mm M16 connectors IP 40 serie 680 Pole Article number Date: 2013-10-02 - Page 2 of 2 Product Area 12 09 0330 00 12 Item description Normen und Prüfbedingungen siehe Binder Katalog Seite T1-16 oder unter www.binder-connector.de Powered by TCPDF (www.tcpdf.org) 09 0330 00 12
09 0330 00 12 价格&库存
很抱歉,暂时无法提供与“09 0330 00 12”相匹配的价格&库存,您可以联系我们找货
