76-4631-0111-00012-0200
    BINDER(宾德)
    BINDER - 76-4631-0111-00012-0200 - Sensor Cable, M12 Plug, Free End, 12 Positions, 200 mm, 7.9 ", 71...
76-4631-0111-00012-0200 数据手册
Product data sheet Automation technology - sensors and actuators Product description M12-A male panel mount connector, Contacts: 12, unshielded, single wires, IP68, UL, M20x1.5 plastic Area Order number M12-A series 763 76 4631 0111 00012-0200 Illustration Scale drawing Contact arrangement (Plug-in side) You can find the assembly instructions on the next page. Technical data General features Order number Connector design Wire length Version Connector locking system Termination Degree of protection Cross-sectional area Temperature range from/to Mechanical operation Weight (g) Customs tariff number Material 76 4631 0111 00012-0200 male panel mount connector 0,2 m connector male straight screw single wires IP68 0.14 mm² / AWG 26 -40 °C / 85 °C > 100 Mating cycles 12.456 85369010 PA PA black CuZn (brass) Au (gold) CAS 80-05-7 (4,4'-isopropylidendiph enol) CAS 7439-92-1 (Lead) CAS 61788-32-7 (Terphenyl, hydrogenated) Authorization/approvals Approvals Electrical parameters Rated voltage Rated impulse voltage Rated current (40 °C) Insulation resistance Pollution degree Overvoltage category Insulating material group EMC compliance Housing material Contact body material Contact material Contact plating REACH SVHC UL 30 V 800 V 2 A (UL 1.5 A) > 10⁸ Ω 3 II III unshielded Date: 2021-04-19 - Page 1 of 3 Product data sheet Automation technology - sensors and actuators Product description M12-A male panel mount connector, Contacts: 12, unshielded, single wires, IP68, UL, M20x1.5 plastic Area Order number M12-A series 763 76 4631 0111 00012-0200 Assembly instructions / Panel cut-out Date: 2021-04-19 - Page 2 of 3 Powered by TCPDF (www.tcpdf.org) Product data sheet Automation technology - sensors and actuators Product description M12-A male panel mount connector, Contacts: 12, unshielded, single wires, IP68, UL, M20x1.5 plastic Area Order number M12-A series 763 76 4631 0111 00012-0200 Security notices The connectors have been developed for applications in plant engineering, control and electrical equipment construction. The user is responsible for checking whether the connectors can also be used in other areas of application. Plug connectors with enclosure protection IP 67 and IP 68 are not suitable for use under water. When used outdoors, the plug connectors must be protected separately against corrosion. For further information on the IP protection classes, please refer to the "Technical Information" download centre. Date: 2021-04-19 - Page 3 of 3
76-4631-0111-00012-0200 价格&库存
很抱歉,暂时无法提供与“76-4631-0111-00012-0200”相匹配的价格&库存,您可以联系我们找货
