79-3110-32-04
79-3110-32-04
    BINDER(宾德)
79-3110-32-04 数据手册
Product data sheet Automation technology - sensors and actuators Product description   Area Order number Illustration M5 female angled connector, Contacts: 4, unshielded, moulded on cable, IP67, M5x0.5, PUR black, 4 x 0.25 mm²   M5 series 707 79 3110 32 04 Scale drawing Contact arrangement (Plug-in side) Technical data General features Order number 79 3110 32 04 Connector design female angled connector Cable length 2m Version connector female angled Connector locking system screw Termination moulded on cable Degree of protection IP67 Cross-sectional area 0.25 mm² / AWG 24 Temperature range from/to -25 °C / 80 °C Mechanical operation > 100 Mating cycles Weight (g) 48.5 Customs tariff number 85444290 Electrical parameters Rated voltage 60 V Rated impulse voltage 800 V Rated current (40 °C) 1A Insulation resistance > 10⁸ Ω Pollution degree 3 Overvoltage category II Insulating material group I EMC compliance unshielded Date: 30.06.2021 Product data sheet Automation technology - sensors and actuators Product description   Area Order number M5 female angled connector, Contacts: 4, unshielded, moulded on cable, IP67, M5x0.5, PUR black, 4 x 0.25 mm²   M5 series 707 79 3110 32 04 Material Housing material PUR Contact body material PUR Contact material CuSn (bronze) Contact plating Au (gold) Locking material CuZn (Brass nickel plated) REACH SVHC CAS 7439-92-1 (Lead) SCIP number 64364b73-0767-4674-9baa-2f392fb4f767 Classifications eCl@ss 11.1 27-06-03-11 ETIM 7.0 EC001855 Declarations of conformity Low Voltage Directive 2014/35/EU (EN 60204-1:2018;EN 60529:1991) RoHS Directive 2011/65/EU (EN 50581:2012) Cable data - Structure of the cable Cable diameter 4.0 mm Cross section 4 x 0.25 mm² Sheath material PUR Single-lead insulation PVC Single-lead structure 32x0.1 mm Cable color black Cable data - Electrical properties Conductor resistance 79.9 Ω/Km (20°C) Cable data - Mechanical properties Bending radius, fixed cable ≥5xØ Bending radius, moving cable ≥ 10 x Ø Cable data - Thermal properties Temperature range cable in move from/to -5°C / +80°C Temperature range cable fixed from/to -25°C / +80°C Cable data - Other features Halogen free No Date: 30.06.2021 Product data sheet Automation technology - sensors and actuators Product description   Area Order number M5 female angled connector, Contacts: 4, unshielded, moulded on cable, IP67, M5x0.5, PUR black, 4 x 0.25 mm²   M5 series 707 79 3110 32 04 Security notices The connectors have been developed for applications in plant engineering, control and electrical equipment construction. The user is responsible for checking whether the connectors can also be used in other areas of application. Plug connectors with enclosure protection IP 67 and IP 68 are not suitable for use under water. When used outdoors, the plug connectors must be protected separately against corrosion. For further information on the IP protection classes, please refer to the "Technical Information" download centre. To lock the cable connector with the device connector, the threaded ring is tightened "hand-tight" (approx. 50 cNm). Date: 30.06.2021
79-3110-32-04 价格&库存
很抱歉,暂时无法提供与“79-3110-32-04”相匹配的价格&库存,您可以联系我们找货
  • 1+185.46003
  • 50+178.04538
  • 100+176.25420
  • 250+174.23391
库存:38
