79-9723-100-08
79-9723-100-08
    BINDER(宾德)
    BINDER - 79-9723-100-08 - Sensor Cable, M12 Plug, RJ45 Plug, 8 Positions, 10 m, 33 ft, 876
79-9723-100-08 数据手册
Product data sheet Automation technology - data transmission and power supply Product description Contacts: 8, Connecting cable 10m, male cable connector M12x1 - RJ45-male connector, shielded, IP67 Area Order number M12-D, M12-X Series 876 X-coding 79 9723 100 08 Illustration Scale drawing Contact arrangement Technical data General values Connector design Connector locking system Termination Wire gauge (AWG) Upper limit temperature Lower limit temperature Electrical values connecting cord bolted moulded on cable 4x2xAWG26 85 °C -40 °C Cable data Sheath material Single-lead insulation Single-lead structure Cable diameter Conductor resistance Temperature range, moving cable, °C from Temperature range, moving cable, °C to Temperature range, fixed cable, °C from Temperature range, fixed cable, °C to Bending radius, fixed cable Approval 1 PUR PE 8 x 0,14 6.2 14,5Ω/100 m -10 60 -40 85 ≥ 50 mm UL listed Rated current (40 °C) Rated voltage Pollution degree Overvoltage category Insulating material group Volume resistivity Insulation resistance EMC compliance Degree of protection Mechanical operation 0,5 A 50V AC, 60V DC V 3 II II ≤ 15 mΩ >10^8Ω shielded IP67 > 100 Mating cycles Material Contact material Contact plating Contact body material Housing material CuZn (brass) Au (gold) PA PUR Date: 2018-11-22 - Page 1 of 2 Powered by TCPDF (www.tcpdf.org) Product data sheet Automation technology - data transmission and power supply Product description Contacts: 8, Connecting cable 10m, male cable connector M12x1 - RJ45-male connector, shielded, IP67 Area Order number M12-D, M12-X Series 876 X-coding 79 9723 100 08 Security notices The connectors are designed for use in plant, control system and electrical equipment. The end user is responsible for checking whether the connectors are suitable for use in other applications. Connectors with degree of protection IP 67 and IP 68 are not suitable for use under water. When used outdoors, the connectors must be separately protected against corrosion. For further information about IP degrees of protection refer to ‘Technical support’ in the Download Centre. To lock the cable connector to the equipment connector, the threaded ring is tightened until it is ‘finger-tight’ (approx. 50 cNm). Date: 2018-11-22 - Page 2 of 2
79-9723-100-08
1. 物料型号:M12-D, M12-X Series 876 X-coding 79 9723 100 08。 2. 器件简介:提供8个接触点的连接线,带有10米长的电缆,M12x1 - RJ45-male 连接器,带有屏蔽,防护等级为IP67。 3. 引脚分配:提供了详细的接触点排列图和尺寸,从1到8号,每个接触点的相对位置都有说明。 4. 参数特性:包括连接器设计、锁定系统、接线规范、线规(AWG)、最高和最低工作温度、电缆数据等。 5. 功能详解:连接器用于工业、控制系统和电气设备,端用户需检查连接器是否适合其他应用。 6. 应用信息:连接器设计用于在工厂、控制系统和电气设备中使用,不适合在水下使用,户外使用时需要额外的防腐蚀保护。 7. 封装信息:包括电缆直径、导体电阻、绝缘材料、接触材料、接触镀层、外壳材料等。
79-9723-100-08 价格&库存
很抱歉,暂时无法提供与“79-9723-100-08”相匹配的价格&库存,您可以联系我们找货
