99 0072 100 02
99 0072 100 02
    BINDER(宾德)
    BINDER - 99 0072 100 02 - Circular Connector, 711 Series, Cable Mount Receptacle, 2 Contacts, Solder...
99 0072 100 02 数据手册
Product sheet Subminiature connectors Female cable connector M9 connectors IP 40 Pole Article number serie 711 illustration scale drawing Date: 2013-12-05 - Page 1 of 2 Product Area 2 99 0072 100 02 Contact Arrangement You can find the item description on the next page. Technical data Common values Material Connector Design Female cable connector Connector locking system Screw Termination solder Wire gauge (mm) 0,25 mm² Wire gauge (AWG) 24 Cable outlet 3 - 4 mm Upper temperature +85 °C Lower temperature -40 °C Electrical values Rated voltage 125 V Rated impulse voltage 1500 V Pollution degree 1 Overvoltage category II Material group III Rated current (40°C) 4A Volume resistivity ≤ 3 mΩ EMV compliance not shieldable Degree of protection IP 40 Mechanical operation >500 mating cycles Material of contact CuSn (bronce) Contact plating Au (gold) Material of contact body PA (UL 94 V-0) Material of housing PA (UL 94 VH-B) Cable data material housing - insulation single lead - single lead structure - conductor resistance - Contacts 2, Female cable connector, cable outlet 3 – 4 mm Normen und Prüfbedingungen siehe Binder Katalog Seite T1-16 oder unter www.binder-connector.de 99 0072 100 02 Product sheet Subminiature connectors Female cable connector M9 connectors IP 40 serie 711 Pole Article number Date: 2013-12-05 - Page 2 of 2 Product Area 2 99 0072 100 02 Item description Normen und Prüfbedingungen siehe Binder Katalog Seite T1-16 oder unter www.binder-connector.de Powered by TCPDF (www.tcpdf.org) 99 0072 100 02
99 0072 100 02 价格&库存
很抱歉,暂时无法提供与“99 0072 100 02”相匹配的价格&库存,您可以联系我们找货
