09 0308 00 03
09 0308 00 03
    BINDER(宾德)
    BINDER - 09 0308 00 03 - Circular Connector, 680 Series, Panel Mount Receptacle, 3 Contacts, Solder ...
09 0308 00 03 数据手册
Product sheet Miniature connectors Female socket, solder M16 connectors IP 40 Pole Article number serie 581/ 680/ 682 illustration scale drawing Date: 2013-06-04 - Page 1 of 2 Product Area 3 DIN 09 0308 00 03 Contact Arrangement You can find the assembly instruction on the next page. Technical data Common values Material Connector Design Female socket Connector locking system Screw-locking Termination solder Wire gauge (mm) 0,75 mm² Wire gauge (AWG) 20 Max. Cable outlet - Upper temperature +85 °C Lower temperature -40 °C Material of contact CuSn (bronce) Contact plating Ag (silver) Material of contact body PBT (UL 94 V-0) Material of housing zinc diecasting, nickel plated Cable data Contacts 3 DIN, female socket, solder, 2 – 8 Contacts, silver plated contacts Electrical values Rated voltage 250 V Rated impulse voltage 1500 V Pollution degree 1 Overvoltage category I Material group III Rated current (40°C) 7A Volume resistivity ≤ 5 mΩ EMV compliance shielded Degree of protection IP 40 Mechanical operation >500 mating cycles Normen und Prüfbedingungen siehe Binder Katalog Seite T1-16 oder unter www.binder-connector.de 09 0308 00 03 Product sheet Miniature connectors Female socket, solder M16 connectors IP 40 serie 581/ 680/ 682 Pole Article number Date: 2013-06-04 - Page 2 of 2 Product Area 3 DIN 09 0308 00 03 Installation instructions / Mounting cutout Normen und Prüfbedingungen siehe Binder Katalog Seite T1-16 oder unter www.binder-connector.de Powered by TCPDF (www.tcpdf.org) 09 0308 00 03
09 0308 00 03 价格&库存
很抱歉,暂时无法提供与“09 0308 00 03”相匹配的价格&库存,您可以联系我们找货
  • 1+60.947221+7.92130
  • 5+54.774255+7.11900
  • 20+48.6882220+6.32800
  • 100+42.68914100+5.54830
库存:155
