09 0474 00 08
09 0474 00 08
    BINDER(宾德)
    BINDER - 09 0474 00 08 - Circular Connector, 680 Series, Panel Mount Receptacle, 8 Contacts, Solder ...
09 0474 00 08 数据手册
Product sheet Miniature connectors Female socket, solder M16 connectors IP 40 Pole Article number serie 581/ 680/ 682 illustration scale drawing Date: 2013-07-15 - Page 1 of 2 Product Area 8 DIN 09 0474 00 08 Contact Arrangement You can find the assembly instruction on the next page. Technical data Common values Material Connector Design Female socket Connector locking system Screw-locking Termination solder Wire gauge (mm) 0,75 mm² Wire gauge (AWG) 20 Max. Cable outlet - Upper temperature +85 °C Lower temperature -40 °C Material of contact CuSn (bronce) Contact plating Ag (silver) Material of contact body PBT (UL 94 V-0) Material of housing zinc diecasting, nickel plated Cable data Contacts 8 DIN, female socket, solder, 2 – 8 Contacts, silver plated contacts Electrical values Rated voltage 60 V Rated impulse voltage 500 V Pollution degree 1 Overvoltage category I Material group III Rated current (40°C) 5A Volume resistivity ≤ 5 mΩ EMV compliance shielded Degree of protection IP 40 Mechanical operation >500 mating cycles Normen und Prüfbedingungen siehe Binder Katalog Seite T1-16 oder unter www.binder-connector.de 09 0474 00 08 Product sheet Miniature connectors Female socket, solder M16 connectors IP 40 serie 581/ 680/ 682 Pole Article number Date: 2013-07-15 - Page 2 of 2 Product Area 8 DIN 09 0474 00 08 Installation instructions / Mounting cutout Normen und Prüfbedingungen siehe Binder Katalog Seite T1-16 oder unter www.binder-connector.de Powered by TCPDF (www.tcpdf.org) 09 0474 00 08
09 0474 00 08 价格&库存
很抱歉,暂时无法提供与“09 0474 00 08”相匹配的价格&库存,您可以联系我们找货
