09 9792 30 05
09 9792 30 05
    BINDER(宾德)
    BINDER - 09 9792 30 05 - Circular Connector, 719 Series, Panel Mount Receptacle, 5 Contacts, Solder ...
09 9792 30 05 数据手册
Product data sheet Subminiature connectors Product description Contacts: 3, female panel mount connector, solder Area Order number Snap-in IP40 Series 709/719 09 9750 30 03 Illustration Scale drawing Contact arrangement You can find the component part drawing and assembly instructions on the next page. Technical data General values Connector design Connector locking system Termination Wire gauge (mm) Wire gauge (AWG) Upper limit temperature Lower limit temperature Electrical values female panel mount connector snap solder 0,25 mm² 24 70 °C -25 °C Rated current (40 °C) Rated voltage Rated impulse voltage Pollution degree Overvoltage category Insulating material group Volume resistivity Insulation resistance EMC compliance Degree of protection Mechanical operation 3A 60 V 800 V 1 II III ≤ 3 mΩ ≥ 10¹⁰Ω Shielding is not possible IP40 > 100 Mating cycles Material Contact material Contact plating Contact body material CuSn (bronze) Au (gold) PA Date: 2018-05-04 - Page 1 of 3 Product data sheet Subminiature connectors Product description Contacts: 3, female panel mount connector, solder Area Order number Snap-in IP40 Series 709/719 09 9750 30 03 Component part drawing Assembly instructions / Panel cut-out Date: 2018-05-04 - Page 2 of 3 Powered by TCPDF (www.tcpdf.org) Product data sheet Subminiature connectors Product description Contacts: 3, female panel mount connector, solder Area Order number Snap-in IP40 Series 709/719 09 9750 30 03 Security notices The connectors are designed for use in plant, control system and electrical equipment. The end user is responsible for checking whether the connectors are suitable for use in other applications. Date: 2018-05-04 - Page 3 of 3
09 9792 30 05 价格&库存
很抱歉,暂时无法提供与“09 9792 30 05”相匹配的价格&库存,您可以联系我们找货
