61-0800-085-00
61-0800-085-00
    BINDER(宾德)
    BINDER - 61-0800-085-00 - Circular Connector Contact, HEC 696, Socket, Crimp, 24 AWG, 26 AWG
61-0800-085-00 数据手册
Accessory data sheet Product description Female contact, set of 5, individual Order number 61 0800 085 00 Illustration Technical data Contact diameter Insulation Diameter Contact material Contact plating Wire gauge (mm) Wire gauge (AWG) Crimp measurement Crimping force 1,5 mm 1,0 - 2,0 mm CuSn (Bronze) Ag (Silber) 0.14 - 0.25 mm² 26 - 24 0,9 - 1 mm DIN EN 60352-2: 24 N Matching products 09 0112 700 04 - Female panel mount connector, crimp 09 0112 780 04 - Female panel mount connector, crimp, screwed from front 09 0116 700 05 - Female panel mount connector, crimp 09 0116 780 05 - Female panel mount connector, crimp, screwed from front 09 0124 700 06 - Female panel mount connector, crimp 09 0124 780 06 - Female panel mount connector, crimp, screwed from front 09 0128 700 07 - Female panel mount connector, crimp 09 0128 780 07 - Female panel mount connector, crimp, screwed from front 09 0174 700 08 - Female panel mount connector, crimp 09 0174 780 08 - Female panel mount connector, crimp, screwed from front 09 0312 700 04 - Female panel mount connector, crimp 09 0312 780 04 - Female panel mount connector, crimp, screwed from front 09 0316 700 05 - Female panel mount connector, crimp 09 0316 780 05 - Female panel mount connector, crimp, screwed from front 09 0324 700 06 - Female panel mount connector, crimp 09 0324 780 06 - Female panel mount connector, crimp, screwed from front 09 0328 700 07 - Female panel mount connector, crimp 09 0328 780 07 - Female panel mount connector, crimp, screwed from front 09 0474 700 08 - Female panel mount connector, crimp 09 0474 780 08 - Female panel mount connector, crimp, screwed from front 09 6491 000 05 - Male panel mount connector 09 6492 000 05 - Female panel mount connector 09 6492 200 05 - Female panel mount connector 09 6503 000 08 - Male panel mount connector 09 6504 000 08 - Female panel mount connector 09 6504 200 08 - Female panel mount connector 09 6519 000 12 - Male panel mount connector Date: 2019-11-22 - Page 1 of 2 Powered by TCPDF (www.tcpdf.org) Accessory data sheet Product description Female contact, set of 5, individual Order number 61 0800 085 00 09 6520 000 12 - Female panel mount connector 09 6520 200 12 - Female panel mount connector 99 2010 700 04 - Female cable connector with cable clamp, CRIMP connection, shieldable, cable outlet 4 - 6 mm 99 2010 702 04 - Female cable connector with cable clamp, CRIMP connection, shieldable, cable outlet 6 - 8 mm 99 2014 700 05 - Female cable connector with cable clamp, CRIMP connection, shieldable, cable outlet 4 - 6 mm 99 2014 702 05 - Female cable connector with cable clamp, CRIMP connection, shieldable, cable outlet 6 - 8 mm 99 2022 700 06 - Female cable connector with cable clamp, CRIMP connection, shieldable, cable outlet 4 - 6 mm 99 2022 702 06 - Female cable connector with cable clamp, CRIMP connection, shieldable, cable outlet 6 - 8 mm 99 2026 700 07 - Female cable connector with cable clamp, CRIMP connection, shieldable, cable outlet 4 - 6 mm 99 2026 702 07 - Female cable connector with cable clamp, CRIMP connection, shieldable, cable outlet 6 - 8 mm 99 2062 700 08 - Female cable connector with cable clamp, CRIMP connection, shieldable, cable outlet 4 - 6 mm 99 2062 702 08 - Female cable connector with cable clamp, CRIMP connection, shieldable, cable outlet 6 - 8 mm 99 5110 700 04 - Female cable connector with cable clamp, CRIMP connection, shieldable, PG 7, cable outlet 4 - 6 mm 99 5110 740 04 - Female cable connector, short version, CRIMP connection, cable outlet 4-8 mm 99 5110 750 04 - Female angled connector, CRIMP connection, shieldable, PG 7, cable outlet 4-6 mm 99 5114 700 05 - Female cable connector with cable clamp, CRIMP connection, shieldable, PG 7, cable outlet 4 - 6 mm 99 5114 740 05 - Female cable connector, short version, CRIMP connection, cable outlet 4-8 mm 99 5114 750 05 - Female angled connector, CRIMP connection, shieldable, PG 7, cable outlet 4-6 mm 99 5122 700 06 - Female cable connector with cable clamp, CRIMP connection, shieldable, PG 7, cable outlet 4 - 6 mm 99 5122 740 06 - Female cable connector, short version, CRIMP connection, cable outlet 4-8 mm 99 5122 750 06 - Female angled connector, CRIMP connection, shieldable, PG 7, cable outlet 4-6 mm 99 5126 700 07 - Female cable connector with cable clamp, CRIMP connection, shieldable, PG 7, cable outlet 4 - 6 mm 99 5126 740 07 - Female cable connector, short version, CRIMP connection, cable outlet 4-8 mm 99 5126 750 07 - Female angled connector, CRIMP connection, shieldable, PG 7, cable outlet 4-6 mm 99 5172 700 08 - Female cable connector with cable clamp, CRIMP connection, shieldable, PG 7, cable outlet 4 - 6 mm 99 5172 740 08 - Female cable connector, short version, CRIMP connection, cable outlet 4-8 mm 99 5172 750 08 - Female angled connector, CRIMP connection, shieldable, PG 7, cable outlet 4-6 mm 99 5610 700 04 - Female cable connector with cable clamp, CRIMP connection, shieldable, PG 9, cable outlet 6 - 8 mm 99 5610 750 04 - Female angled connector, CRIMP connection, shieldable, PG 9, cable outlet 6-8 mm 99 5614 700 05 - Female cable connector with cable clamp, CRIMP connection, shieldable, PG 9, cable outlet 6 - 8 mm 99 5614 750 05 - Female angled connector, CRIMP connection, shieldable, PG 9, cable outlet 6-8 mm 99 5622 700 06 - Female cable connector with cable clamp, CRIMP connection, shieldable, PG 9, cable outlet 6 - 8 mm 99 5622 750 06 - Female angled connector, CRIMP connection, shieldable, PG 9, cable outlet 6-8 mm 99 5626 700 07 - Female cable connector with cable clamp, CRIMP connection, shieldable, PG 9, cable outlet 6 - 8 mm 99 5626 750 07 - Female angled connector, CRIMP connection, shieldable, PG 9, cable outlet 6-8 mm 99 5672 700 08 - Female cable connector with cable clamp, CRIMP connection, shieldable, PG 9, cable outlet 6 - 8 mm 99 5672 750 08 - Female angled connector, CRIMP connection, shieldable, PG 9, cable outlet 6-8 mm 99 6489 000 05 - Male cable connector 99 6490 000 05 - Female cable connector 99 6501 000 08 - Male cable connector 99 6502 000 08 - Female cable connector 99 6517 000 12 - Male cable connector 99 6518 000 12 - Female cable connector Date: 2019-11-22 - Page 2 of 2
61-0800-085-00 价格&库存
很抱歉,暂时无法提供与“61-0800-085-00”相匹配的价格&库存,您可以联系我们找货
