76-0932-0111-00004-0200
    BINDER(宾德)
    BINDER - 76-0932-0111-00004-0200 - Sensor Cable, M12 Receptacle, Free End, 4 Positions, 200 mm, 7.9 ...
76-0932-0111-00004-0200 数据手册
Product data sheet Automation technology - sensors and actuators Product description   Area Order number Illustration M12-A square female panel mount connector, Contacts: 4, unshielded, single wires, IP40, UL, square   M12-A series 763 76 0932 0111 00004-0200 Scale drawing Contact arrangement (Plug-in side) You can find the assembly instructions on the next page. Technical data General features Order number 76 0932 0111 00004-0200 Alternative order number: 09 3448 00 04 Notice Please note that, due to the change from the old to the new order number, there may be deviations in the technical specifications. For questions about product details, please use the ‘Contact Customer Service’ form on the right. Connector design square female panel mount connector Wire length 0,2 m Version connector female straight Connector locking system screw Termination single wires Degree of protection IP40 IP67 with seal, see accessories Cross-sectional area 0.25 mm² / AWG 24 Temperature range from/to -40 °C / 85 °C Mechanical operation > 100 Mating cycles Weight (g) 16.446 Customs tariff number 85369010 Electrical parameters Rated voltage 250 V Rated impulse voltage 2500 V Rated current (40 °C) 4 A (3 A UL) Insulation resistance > 10⁸ Ω Pollution degree 3 Date: 30.06.2021 Product data sheet Automation technology - sensors and actuators Product description   Area Order number M12-A square female panel mount connector, Contacts: 4, unshielded, single wires, IP40, UL, square   M12-A series 763 76 0932 0111 00004-0200 Overvoltage category II Insulating material group III EMC compliance unshielded Material Housing material CuZn (Brass nickel plated) Contact body material PA black Contact material CuSn (bronze) Contact plating Au (gold) Authorization/approvals Approvals UL Classifications eCl@ss 11.1 27-44-01-03 ETIM 7.0 EC003570 Date: 30.06.2021 Product data sheet Automation technology - sensors and actuators Product description   Area Order number M12-A square female panel mount connector, Contacts: 4, unshielded, single wires, IP40, UL, square   M12-A series 763 76 0932 0111 00004-0200 Assembly instructions / Panel cut-out Date: 30.06.2021 Product data sheet Automation technology - sensors and actuators Product description   Area Order number M12-A square female panel mount connector, Contacts: 4, unshielded, single wires, IP40, UL, square   M12-A series 763 76 0932 0111 00004-0200 Security notices The connector must not be plugged or unplugged under load. Non-observance and improper use can result in personal injury. The connectors have been developed for applications in plant engineering, control and electrical equipment construction. The user is responsible for checking whether the connectors can also be used in other areas of application. The protection class specification applies on condition that the four mounting holes are made as blind holes. Date: 30.06.2021
76-0932-0111-00004-0200 价格&库存
很抱歉,暂时无法提供与“76-0932-0111-00004-0200”相匹配的价格&库存,您可以联系我们找货
  • 1+115.69773
  • 10+106.38776
库存:36
