Product data sheet
Power connectors
Product description
RD24 female cable connector, Contacts: 6+PE, 6.0 - 9.5 mm, shielding is not possible, solder, IP67, UL, ESTI+, VDE, PG9
Area
Order number
RD24 series 693
99 4226 00 07
Illustration
Scale drawing
Contact arrangement
Derating curve
You can find the component part drawing and assembly
instructions on the next page.
Technical data
General values
Connector design
Connector locking system
Termination
Wire gauge (mm)
Wire gauge (AWG)
Cable outlet
Upper limit temperature
Lower limit temperature
Customs tariff number
Packaging Unit
Electrical values
screw
solder
max. 0.75 mm²
max. 18
6.0 - 9.5 mm
100 °C
– 40 °C
85369010
40
Rated current (40 °C)
Rated voltage
Rated impulse voltage
Pollution degree
Overvoltage category
Insulating material group
Insulation resistance
EMC compliance
Degree of protection
UL
ESTI+
VDE
Material
Cable data
Approval 1
Approval 2
Approval 3
Degree of protection 2
Mechanical operation
Contact material
Contact plating
Contact body material
10 A (8 A UL)
250 V
4000 V
3
III
III
≥ 10¹⁰ Ω
IP67
IP65 with cable diameter 6-7 mm
> 500 Mating cycles
CuSn (bronze)
Ag (silver)
PBT (UL94 V-0)
Date: 2020-01-19 - Page 1 of 3
Product data sheet
Power connectors
Product description
Area
Order number
RD24 series 693
99 4226 00 07
Component part drawing
Assembly instructions / Panel cut-out
Date: 2020-01-19 - Page 2 of 3
Powered by TCPDF (www.tcpdf.org)
Product data sheet
Power connectors
Product description
Area
Order number
RD24 series 693
99 4226 00 07
Security notices
The connector must not be connected or separated under load. Non-observance and incorrect use can result in
personal injury.
The connectors are designed for use in plant, control system and electrical equipment. The end user is responsible
for checking whether the connectors are suitable for use in other applications.
To prevent the connector being opened unintentionally when used in electrical circuits containing hazardous life
parts, the thread between the housing and the connector head must be secured using a suitable cyanoacrylate
adhesive. This does not apply to connectors used in SELV and PELV circuits according to IEC 61140 (EN 61140, VDE
0140-1).
Connectors used in electrical circuits containing hazardous life parts must only be assembled and used by or under
the supervision of persons with the requisite electrotechnical training, taking the applicable regulations and
standards into account.
Connectors with degree of protection IP 67 and IP 68 are not suitable for use under water. When used outdoors, the
connectors must be separately protected against corrosion. For further information about IP degrees of protection
refer to ‘Technical support’ in the Download Centre.
To lock the cable connector to the equipment connector, the threaded ring is tightened until it is ‘finger-tight’
(approx. 50 cNm).
Date: 2020-01-19 - Page 3 of 3
很抱歉,暂时无法提供与“99-4226-00-07”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+185.29341
- 10+182.27339
- 50+177.49344
- 100+172.64059
- 250+168.93327
