99-9480-100-08
99-9480-100-08
    BINDER(宾德)
99-9480-100-08 数据手册
Product sheet Subminiature Product Contacts: 8, female cable connector, cable outlet 3 -4 mm Area Article number Bayonet IP40 Series 710 99 9480 100 08 Illustration Scale drawing Contact Arrangement You can find the item description on the next page. Technical data Common values Connector Design Connector locking system Termination Wire gauge (mm) Wire gauge (AWG) Cable outlet Upper temperature Lower temperature Electrical values Cable socket Bayonet solder 0,14 mm² 26 3 - 4 mm 85 °C -40 °C Rated voltage Rated impulse voltage Pollution degree Overvoltage category Material group Rated current (40°C) Volume resistivity EMV compliance Degree of protection Mechanical operation 125 1500 V 1 II III 1A ≤ 3 mΩ Shielding is not possible IP40 > 500 Mating cycles Material Material of contact Contact plating Material of contact body CuSn (Bronze) Au (gold) PA (UL 94 V-0) Date: 2016-04-25 - Page 1 of 2 Powered by TCPDF (www.tcpdf.org) Product sheet Subminiature Product Contacts: 8, female cable connector, cable outlet 3 -4 mm Area Article number Bayonet IP40 Series 710 99 9480 100 08 Item description Date: 2016-04-25 - Page 2 of 2
99-9480-100-08
1. 物料型号:Bayonet IP40 Series 710 99 9480 100 08 2. 器件简介:8针小型母头电缆连接器,3-4毫米电缆出口,带有防尘盖。 3. 引脚分配:引脚编号从1到8,具体位置如下: - 1: X = -0.90 至 -1.65, Y = 未提供 - 2: X = -1.85 至 -0.35, Y = 未提供 - 3: X = -1.45, Y = 1.20 - 4: X = 0.00, Y = 1.85 - 5: X = 1.45, Y = 1.20 - 6: X = 1.85, Y = -0.35 - 7: X = 0.90, Y = -1.65 - 8: X = 0.00, Y = 0.00 4. 参数特性: - 额定电压:125V AC 或 1500V DC - 额定电流:1A - 接触电阻:≤3 mΩ - 屏蔽:不可屏蔽 - 污染等级:IP40 - 机械寿命:>500次配对循环 - 材料组:CuSn(青铜)和Au(金) - 材料:PA(UL 94 V-0) 5. 功能详解:该连接器设计为电缆插座,采用焊接方式,适用于0.14 mm²的导线,具有防尘功能。 6. 应用信息:适用于需要防尘保护和电气连接的场合。 7. 封装信息:产品包括触发盒上部(黑色)、压力螺丝、卷轴盒和包装。
99-9480-100-08 价格&库存
很抱歉,暂时无法提供与“99-9480-100-08”相匹配的价格&库存,您可以联系我们找货
    • 1+117.52016
    • 25+114.93752
    • 50+112.46944
    库存:48
