09 0314 00 05
09 0314 00 05
    BINDER(宾德)
    连接器: M16; 680; 插头; 母; 焊接; 锁定: 内螺纹,螺纹接头; 150V; 6A; IP40; PIN: 5; 用于电缆; 直
09 0314 00 05 数据手册
Product sheet Miniature connectors Female cable connector, cable outlet 3-6 mm M16 connectors IP 40 illustration Pole Article number serie 680 scale drawing Date: 2013-12-05 - Page 1 of 2 Product Area 5 09 0314 00 05 Contact Arrangement You can find the item description on the next page. Technical data Common values Material Connector Design Female cable connector Connector locking system Screw Termination solder Wire gauge (mm) 0,75 mm² Wire gauge (AWG) 20 Cable outlet 3 - 6 mm Upper temperature +85 °C Lower temperature -40 °C Material of contact CuSn (bronce) Contact plating Ag (silver) Material of contact body PBT (UL 94 V-0) Material of housing PA (UL 94 HB) Cable data Contacts 5, female cable connector, cable outlet 3 – 6 mm, silver plated contacts Electrical values Rated voltage 250 V Rated impulse voltage 1500 V Pollution degree 1 Overvoltage category I Material group III Rated current (40°C) 6A Volume resistivity ≤ 5 mΩ EMV compliance not shielded Degree of protection IP 40 Mechanical operation >500 mating cycles Normen und Prüfbedingungen siehe Binder Katalog Seite T1-16 oder unter www.binder-connector.de 09 0314 00 05 Product sheet Miniature connectors Female cable connector, cable outlet 3-6 mm M16 connectors IP 40 serie 680 Pole Article number Date: 2013-12-05 - Page 2 of 2 Product Area 5 09 0314 00 05 Item description Normen und Prüfbedingungen siehe Binder Katalog Seite T1-16 oder unter www.binder-connector.de Powered by TCPDF (www.tcpdf.org) 09 0314 00 05
09 0314 00 05 价格&库存
很抱歉,暂时无法提供与“09 0314 00 05”相匹配的价格&库存,您可以联系我们找货
