09-0412-00-04
09-0412-00-04
    BINDER(宾德)
09-0412-00-04 数据手册
Product sheet Subminiature connectors Female socket, solder M9 connectors IP 67 Pole Article number serie 712/702 illustration scale drawing Date: 2013-07-03 - Page 1 of 2 Product Area 4 09 0412 00 04 Contact Arrangement You can find the assembly instruction on the next page. Technical data Common values Material Connector Design Female socket Connector locking system Screw-locking Termination solder Wire gauge (mm) 0,25 mm² Wire gauge (AWG) 24 Max. Cable outlet - Upper temperature +85 °C Lower temperature -40 °C Electrical values Rated voltage 125 V Rated impulse voltage 1500 V Pollution degree 1 Overvoltage category II Material group III Rated current (40°C) 3A Volume resistivity ≤ 3 mΩ EMV compliance shieldable Degree of protection IP 67 Mechanical operation >500 mating cycles Material of contact CuSn (bronce) Contact plating Au (gold) Material of contact body PA (UL 94 V-0) Material of housing CUZn (brass nickel plated) Cable data material housing - insulation single lead - single lead structure - conductor resistance - Contacts 4, Female socket, solder Normen und Prüfbedingungen siehe Binder Katalog Seite T1-16 oder unter www.binder-connector.de 09 0412 00 04 Product sheet Subminiature connectors Female socket, solder M9 connectors IP 67 serie 712/702 Pole Article number Date: 2013-07-03 - Page 2 of 2 Product Area 4 09 0412 00 04 Installation instructions / Mounting cutout Normen und Prüfbedingungen siehe Binder Katalog Seite T1-16 oder unter www.binder-connector.de Powered by TCPDF (www.tcpdf.org) 09 0412 00 04
09-0412-00-04 价格&库存
很抱歉,暂时无法提供与“09-0412-00-04”相匹配的价格&库存,您可以联系我们找货
  • 10+85.76837
  • 50+85.28933
  • 100+81.03007
  • 250+76.97909
库存:459
09-0412-00-04
  • 1+86.12244
  • 10+85.76837
  • 50+85.28933
  • 100+81.03007
  • 250+76.97909
库存:68
