09-4219-00-07
09-4219-00-07
    BINDER(宾德)
09-4219-00-07 数据手册
Product data sheet Power connectors Product description RD24 male panel mount connector, Contacts: 6+PE, shielding is not possible, screw clamp, IP67, UL, ESTI+, VDE Area Order number RD24 series 693 09 4219 00 07 Illustration Scale drawing Contact arrangement Derating curve You can find the assembly instructions on the next page. Technical data General values Connector design Connector locking system Termination Wire gauge (mm) Wire gauge (AWG) Upper limit temperature Lower limit temperature Customs tariff number Packaging Unit Electrical values male panel mount connector screw screw clamp max. 1.50 mm² max. 16 100 °C – 40 °C 85369010 10 Cable data Approval 1 Approval 2 Approval 3 UL ESTI+ VDE Rated current (40 °C) Rated voltage Rated impulse voltage Pollution degree Overvoltage category Insulating material group Insulation resistance EMC compliance Degree of protection Mechanical operation 10 A (8 A UL) 250 V 4000 V 3 III III ≥ 10¹⁰ Ω shielding is not possible IP67 > 500 Mating cycles Material Contact material Contact plating Contact body material Housing material CuZn (brass) Ag (silver) PBT PA Date: 2020-01-19 - Page 1 of 3 Product data sheet Power connectors Product description RD24 male panel mount connector, Contacts: 6+PE, shielding is not possible, screw clamp, IP67, UL, ESTI+, VDE Area Order number RD24 series 693 09 4219 00 07 Assembly instructions / Panel cut-out Date: 2020-01-19 - Page 2 of 3 Powered by TCPDF (www.tcpdf.org) Product data sheet Power connectors Product description RD24 male panel mount connector, Contacts: 6+PE, shielding is not possible, screw clamp, IP67, UL, ESTI+, VDE Area Order number RD24 series 693 09 4219 00 07 Security notices The connector must not be connected or separated under load. Non-observance and incorrect use can result in personal injury. The connectors are designed for use in plant, control system and electrical equipment. The end user is responsible for checking whether the connectors are suitable for use in other applications. Connectors with degree of protection IP 67 and IP 68 are not suitable for use under water. When used outdoors, the connectors must be separately protected against corrosion. For further information about IP degrees of protection refer to ‘Technical support’ in the Download Centre. Date: 2020-01-19 - Page 3 of 3
09-4219-00-07 价格&库存
很抱歉,暂时无法提供与“09-4219-00-07”相匹配的价格&库存,您可以联系我们找货
  • 1+105.58590
  • 10+102.85747
  • 50+99.79580
  • 100+97.11945
  • 250+94.99503
库存:64
09-4219-00-07
  • 10+102.85747
  • 50+99.79580
  • 100+97.11945
  • 250+94.99503
库存:140
