09-6519-000-12
09-6519-000-12
    BINDER(宾德)
    BINDER - 09-6519-000-12 - Circular Connector, 26-16AWG, HEC 696 Series, Flange Mount Plug, 12 Contac...
09-6519-000-12 数据手册
Product sheet power connector Product Polzahl 12: Flanschstecker Area Article number Bajonett HEC Power Series 696 09 6519 000 12 Illustration Scale drawing Contact Arrangement You can find the item description and assembly instruction on the next page. Technical data Common values Connector Design Connector locking system Termination Wire gauge (mm) Wire gauge (AWG) Upper temperature Lower temperature Electrical values Male panel mount connector Bayonet Crimp 0.14 -1.0 mm² 26-16 100 °C -40 °C Rated voltage Rated impulse voltage Pollution degree Overvoltage category Material group Rated current (40°C) Volume resistivity Degree of protection Mechanical operation 250 V 5000 V 3 III I,II 5A ≤ 8 mΩ IP68/IP69K > 1000 mating cycles Material Material of contact Contact plating Material of contact body Material of housing Ag (Silver) PA PA Date: 2016-01-20 - Page 1 of 3 Product sheet power connector Product Polzahl 12: Flanschstecker Area Article number Bajonett HEC Power Series 696 09 6519 000 12 Item description Installation instructions / Mounting cutout Date: 2016-01-20 - Page 2 of 3 Powered by TCPDF (www.tcpdf.org) Product sheet power connector Product Polzahl 12: Flanschstecker Area Article number Bajonett HEC Power Series 696 09 6519 000 12 Installation instructions / Mounting cutout Installation instructions / Mounting cutout Date: 2016-01-20 - Page 3 of 3
09-6519-000-12 价格&库存
很抱歉,暂时无法提供与“09-6519-000-12”相匹配的价格&库存,您可以联系我们找货
    • 1+89.16328
    • 10+81.99856
    • 25+74.04239
    库存:50
