99-0437-19-05
99-0437-19-05
    BINDER(宾德)
99-0437-19-05 数据手册
Product sheet Automation technology Male cable connector, Power M12 connectors A-Coding Pole Article number serie 713 Deratingkurven illustration Contact Arrangement You can find the assembly instruction on the next page. Date: 2014-04-16 - Page 1 of 2 Product Area 5 99 0437 19 05 scale drawing Technical data Common values Material Connector Design Male cable connector Connector locking system Screw Termination screw clamp Wire gauge (mm) max. 1,5 mm² Wire gauge (AWG) max. 16 Cable outlet 8 - 10 mm Upper temperature +85 °C Lower temperature -40 °C Material of contact CuZn (brass) Contact plating CuSnZn (Optalloy) Material of contact body PA Material of housing PA Cable data Contacts: 5, Cable outlet: 8 - 10 mm, Male cable connector, Power Electrical values Rated voltage 125 V Rated impulse voltage 1500 V Pollution degree 3 Overvoltage category II Material group II Rated current (40°C) contact 1-4 8A, contact 5 2A Volume resistivity ≤ 3 mΩ Degree of protection IP 67 Mechanical operation >100 mating cycles Normen und Prüfbedingungen siehe Binder Katalog Seite T1-16 oder unter www.binder-connector.de 99 0437 19 05 Product sheet Automation technology Male cable connector, Power M12 connectors A-Coding serie 713 Pole Article number Date: 2014-04-16 - Page 2 of 2 Product Area 5 99 0437 19 05 Installation instructions / Mounting cutout Normen und Prüfbedingungen siehe Binder Katalog Seite T1-16 oder unter www.binder-connector.de Powered by TCPDF (www.tcpdf.org) 99 0437 19 05
99-0437-19-05 价格&库存
很抱歉,暂时无法提供与“99-0437-19-05”相匹配的价格&库存,您可以联系我们找货
    • 1+86.45568
    • 13+84.72698
    • 25+83.02953
    库存:581
