Product data sheet
Automation technology - sensors and actuators
Product description
M8 cable connector, Contacts: 3, 3.5 - 5.0 mm, shieldable, solder, IP67, UL listed
Area
Order number
M8 series 768
99 3361 00 03
Illustration
Scale drawing
Contact arrangement
You can find the component part drawing and assembly instructions on the next page.
Technical data
General values
Connector design
Connector locking system
Termination
Wire gauge (mm)
Wire gauge (AWG)
Cable outlet
Upper limit temperature
Lower limit temperature
Customs tariff number
Packaging Unit
Electrical values
cable connector
screw
solder
0.25 mm²
24
3.5 - 5.0 mm
85 °C
– 40 °C
85369010
100
4A
60 V
1500 V
3
III
III
shieldable
IP67
> 100 Mating cycles
Material
Cable data
Approval 1
Rated current (40 °C)
Rated voltage
Rated impulse voltage
Pollution degree
Overvoltage category
Insulating material group
EMC compliance
Degree of protection
Mechanical operation
UL listed
Contact material
Contact plating
Contact body material
CuZn (brass)
Au (gold)
PA
Date: 2020-01-18 - Page 1 of 3
Product data sheet
Product description
Area
Order number
M8 series 768
99 3361 00 03
Component part drawing
Assembly instructions / Panel cut-out
Date: 2020-01-18 - Page 2 of 3
Powered by TCPDF (www.tcpdf.org)
Product data sheet
Product description
Area
Order number
M8 series 768
99 3361 00 03
Security notices
The connectors are designed for use in plant, control system and electrical equipment. The end user is responsible
for checking whether the connectors are suitable for use in other applications.
Connectors with degree of protection IP 67 and IP 68 are not suitable for use under water. When used outdoors, the
connectors must be separately protected against corrosion. For further information about IP degrees of protection
refer to ‘Technical support’ in the Download Centre.
To lock the cable connector to the equipment connector, the threaded ring is tightened until it is ‘finger-tight’
(approx. 50 cNm).
Date: 2020-01-18 - Page 3 of 3
很抱歉,暂时无法提供与“99-3361-00-03”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+75.61487
- 10+74.82342
- 50+73.29259
