99-0617-00-06
99-0617-00-06
    BINDER(宾德)
99-0617-00-06 数据手册
Product data sheet Miniature connectors Product description Bayonet cable connector, Contacts: 6 DIN, 3.0 - 6.0 mm, shielding is not possible, solder, IP40 Area Order number Bayonet series 678 99 0617 00 06 Illustration Scale drawing Contact arrangement You can find the component part drawing on the next page. Technical data General values Connector design Connector locking system Termination Wire gauge (mm) Wire gauge (AWG) Cable outlet Upper limit temperature Lower limit temperature Customs tariff number Packaging Unit Electrical values cable connector Bayonet solder 0.75 mm² 18 3.0 - 6.0 mm 85 °C – 40 °C 85369010 40 Rated current (40 °C) Rated voltage Rated impulse voltage Pollution degree Overvoltage category Insulating material group Insulation resistance EMC compliance Degree of protection Mechanical operation 6A 250 V 1500 V 1 I III ≥ 10¹⁰ Ω shielding is not possible IP40 > 500 Mating cycles Material Contact material Contact plating Contact body material Housing material CuZn (brass) Ag (silver) PBT (UL94 V-0) PA Date: 2020-01-19 - Page 1 of 3 Product data sheet Miniature connectors Product description Bayonet cable connector, Contacts: 6 DIN, 3.0 - 6.0 mm, shielding is not possible, solder, IP40 Area Order number Bayonet series 678 99 0617 00 06 Component part drawing Date: 2020-01-19 - Page 2 of 3 Powered by TCPDF (www.tcpdf.org) Product data sheet Miniature connectors Product description Bayonet cable connector, Contacts: 6 DIN, 3.0 - 6.0 mm, shielding is not possible, solder, IP40 Area Order number Bayonet series 678 99 0617 00 06 Security notices The connector must not be connected or separated under load. Non-observance and incorrect use can result in personal injury. The connectors are designed for use in plant, control system and electrical equipment. The end user is responsible for checking whether the connectors are suitable for use in other applications. Connectors used in electrical circuits containing hazardous life parts must only be assembled and used by or under the supervision of persons with the requisite electrotechnical training, taking the applicable regulations and standards into account. The connector is not suitable for mains voltages. Please observe the pollution degrees and the overvoltage category. For further information refer to ‘Technical support’ in the Download Centre. Date: 2020-01-19 - Page 3 of 3
99-0617-00-06 价格&库存
很抱歉,暂时无法提供与“99-0617-00-06”相匹配的价格&库存,您可以联系我们找货
