Product data sheet
Subminiature connectors
Product description
Snap-In IP67 female cable connector, Contacts: 3, 3.0 - 5.0 mm, shielding is not possible, solder, IP67
Area
Order number
Snap-In IP67 series 620
99 9206 00 03
Illustration
Scale drawing
Contact arrangement
You can find the component part drawing on the next page.
Technical data
General values
Connector design
Connector locking system
Termination
Wire gauge (mm)
Wire gauge (AWG)
Cable outlet
Upper limit temperature
Lower limit temperature
Customs tariff number
Packaging Unit
Electrical values
snap
solder
0.25 mm²
24
3.0 - 5.0 mm
85 °C
– 25 °C
85369010
100
Rated current (40 °C)
Rated voltage
Rated impulse voltage
Pollution degree
Overvoltage category
Insulating material group
Insulation resistance
EMC compliance
Degree of protection
Mechanical operation
3A
125 V
1500 V
2
II
II
≥ 10¹⁰ Ω
IP67
> 500 Mating cycles
Material
Contact material
Contact plating
Contact body material
Housing material
CuSn (bronze)
Au (gold)
PA (UL94 V-0)
PA
Date: 2020-01-19 - Page 1 of 3
Product data sheet
Product description
Area
Order number
99 9206 00 03
Component part drawing
Date: 2020-01-19 - Page 2 of 3
Powered by TCPDF (www.tcpdf.org)
Product data sheet
Product description
Area
Order number
99 9206 00 03
Security notices
The connector must not be connected or separated under load. Non-observance and incorrect use can result in
personal injury.
The connectors are designed for use in plant, control system and electrical equipment. The end user is responsible
for checking whether the connectors are suitable for use in other applications.
To prevent the connector being opened unintentionally when used in electrical circuits containing hazardous life
parts, the thread between the housing and the connector head must be secured using a suitable cyanoacrylate
adhesive. This does not apply to connectors used in SELV and PELV circuits according to IEC 61140 (EN 61140, VDE
0140-1).
Connectors used in electrical circuits containing hazardous life parts must only be assembled and used by or under
the supervision of persons with the requisite electrotechnical training, taking the applicable regulations and
standards into account.
Connectors with degree of protection IP 67 and IP 68 are not suitable for use under water. When used outdoors, the
connectors must be separately protected against corrosion. For further information about IP degrees of protection
refer to ‘Technical support’ in the Download Centre.
Date: 2020-01-19 - Page 3 of 3
很抱歉,暂时无法提供与“99-9206-00-03”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+74.62556
- 25+72.96976
- 50+71.39727
- 国内价格
- 100+66.43508
- 200+64.77511
- 400+63.77851
