Product sheet
Subminiature connectors
Female socket
Snap-in connectors IP 67
Pole
Article number
serie 620
illustration
scale drawing
Date: 2013-07-03 - Page 1 of 2
Product
Area
4
99 9212 00 04
Contact Arrangement
You can find the item description and assembly instruction on the next page.
Technical data
Common values
Material
Connector Design
Female socket
Connector locking system
Snap-in locking
Termination
solder
Wire gauge (mm)
0,25 mm²
Wire gauge (AWG)
24
Max. Cable outlet
3 - 5 mm
Upper temperature
+85 °C
Lower temperature
-25 °C
Electrical values
Rated voltage
125 V
Rated impulse voltage
1500 V
Pollution degree
2
Overvoltage category
II
Material group
II
Rated current (40°C)
2.5 A
Volume resistivity
≤ 3 mΩ
EMV compliance
not shieldable
Degree of protection
IP 67
Mechanical operation
>500 mating cycles
Material of contact
CuSn (bronce)
Contact plating
Au (gold)
Material of contact body
PA (UL 94 V-0)
Material of housing
PA (UL 94 V-0)
Cable data
material housing
insulation single lead
single lead structure
conductor resistance
Contacts 4, Female socket
Normen und Prüfbedingungen siehe Binder Katalog Seite T1-16 oder unter www.binder-connector.de
99 9212 00 04
Product sheet
Female socket
serie 620
Pole
Article number
Date: 2013-07-03 - Page 2 of 2
Product
Area
4
99 9212 00 04
Item description
Installation instructions / Mounting cutout
Powered by TCPDF (www.tcpdf.org)
99 9212 00 04
很抱歉,暂时无法提供与“99-9212-00-04”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+53.35691
- 10+52.21787
- 100+51.07883
- 250+50.05844
- 500+49.03805
- 1000+48.01766
- 国内价格
- 1+45.02944
- 25+44.02971
- 50+43.10288
