08-2433-400-001
08-2433-400-001
    BINDER(宾德)
    BINDER - 08-2433-400-001 - Connector Accessory, Adaptor, Binder 720 Series Circular Connector, 720 S...
08-2433-400-001 数据手册
Product data sheet Connectors for medical applications Product description Contacts: 3, male panel mount connector, black, dip-solder Area Order number Snap-in IP67, miniature Series 720 MED 08 2433 400 001 Illustration Scale drawing You can find the component part drawing and assembly instructions on the next page. Technical data General values Connector design Connector locking system Termination Electrical values adapter snap plugable Pollution degree Overvoltage category EMC compliance Degree of protection 2 II not shielded IP67 Material Contact plating Housing material Au (gold) PA Date: 2018-11-22 - Page 1 of 3 Product data sheet Connectors for medical applications Product description Contacts: 3, male panel mount connector, black, dip-solder Area Order number Snap-in IP67, miniature Series 720 MED 08 2433 400 001 Component part drawing Assembly instructions / Panel cut-out Date: 2018-11-22 - Page 2 of 3 Powered by TCPDF (www.tcpdf.org) Product data sheet Connectors for medical applications Product description Contacts: 3, male panel mount connector, black, dip-solder Area Order number Snap-in IP67, miniature Series 720 MED 08 2433 400 001 Security notices The connector must not be connected or separated under load. Non-observance and incorrect use can result in personal injury. The connectors are designed for use in plant, control system and electrical equipment. The end user is responsible for checking whether the connectors are suitable for use in other applications. Connectors with degree of protection IP 67 and IP 68 are not suitable for use under water. When used outdoors, the connectors must be separately protected against corrosion. For further information about IP degrees of protection refer to ‘Technical support’ in the Download Centre. Date: 2018-11-22 - Page 3 of 3
08-2433-400-001 价格&库存
很抱歉,暂时无法提供与“08-2433-400-001”相匹配的价格&库存,您可以联系我们找货
