09 9767 70 04
09 9767 70 04
    BINDER(宾德)
    BINDER - 09 9767 70 04 - Circular Connector, 719 Series, Cable Mount Plug, 4 Contacts, Solder Pin, S...
09 9767 70 04 数据手册
Product data sheet Subminiature connectors Product description Contacts: 4, cable plug connector with strain relief, max. cable outlet 4 mm Area Order number Snap-in IP40 Series 719 09 9767 70 04 Illustration Scale drawing Contact arrangement You can find the component part drawing on the next page. Technical data General values Connector design Connector locking system Termination Wire gauge (mm) Wire gauge (AWG) Cable outlet Upper limit temperature Lower limit temperature Electrical values cable connector snap solder 0.25 mm² 24 2,5 - 4,0 mm 70 °C -25 °C Rated current (40 °C) Rated voltage Rated impulse voltage Pollution degree Overvoltage category Insulating material group Volume resistivity Insulation resistance EMC compliance Degree of protection Mechanical operation 3A 60 V 800 V 1 II III ≤ 3 mΩ ≥ 10¹⁰Ω Shielding is not possible IP40 > 100 Mating cycles Material Contact material Contact plating Contact body material Housing material CuZn (brass) Au (gold) PA PA Date: 2019-03-06 - Page 1 of 3 Product data sheet Subminiature connectors Product description Contacts: 4, cable plug connector with strain relief, max. cable outlet 4 mm Area Order number Snap-in IP40 Series 719 09 9767 70 04 Component part drawing Date: 2019-03-06 - Page 2 of 3 Powered by TCPDF (www.tcpdf.org) Product data sheet Subminiature connectors Product description Contacts: 4, cable plug connector with strain relief, max. cable outlet 4 mm Area Order number Snap-in IP40 Series 719 09 9767 70 04 Security notices The connectors are designed for use in plant, control system and electrical equipment. The end user is responsible for checking whether the connectors are suitable for use in other applications. Date: 2019-03-06 - Page 3 of 3
09 9767 70 04 价格&库存
很抱歉,暂时无法提供与“09 9767 70 04”相匹配的价格&库存,您可以联系我们找货
