09-0132-290-12
09-0132-290-12
    BINDER(宾德)
    BINDER - 09-0132-290-12 - Circular Connector, 723 Series, Panel Mount Receptacle, 12 Contacts, PCB S...
09-0132-290-12 数据手册
Product data sheet Miniature connectors Product description   Area Order number M16 IP67 female panel mount connector, Contacts: 12, shieldable, dip-solder, IP67, UL, front mounting   M16 IP67 series 723 09 0132 290 12 Illustration Conductor layout Scale drawing Contact arrangement (Plug-in side) You can find the assembly instructions on the next page. Technical data General features Order number 09 0132 290 12 Connector design female panel mount connector Version connector female straight Connector locking system screw Termination dip-solder Degree of protection IP67 Temperature range from/to -40 °C / 95 °C Mechanical operation > 500 Mating cycles Date: 20.06.2021 Product data sheet Miniature connectors Product description   Area Order number M16 IP67 female panel mount connector, Contacts: 12, shieldable, dip-solder, IP67, UL, front mounting   M16 IP67 series 723 09 0132 290 12 Weight (g) 9.296 Customs tariff number 85369010 Electrical parameters Rated voltage 60 V Rated impulse voltage 500 V Rated current (40 °C) 5A Insulation resistance ≥ 10¹⁰ Ω Pollution degree 1 Overvoltage category I Insulating material group III EMC compliance shieldable Shield connection Shield pin Material Housing material Zinc die-cast nickel-plated Contact body material PBT (UL94 V-0) Contact material CuSn (bronze) Contact plating Au (gold) REACH SVHC CAS 7439-92-1 (Lead) SCIP number None (No pollutants) Authorization/approvals Approvals UL Classifications eCl@ss 11.1 27-44-01-09 ETIM 7.0 EC003569 Date: 20.06.2021 Product data sheet Miniature connectors Product description   Area Order number M16 IP67 female panel mount connector, Contacts: 12, shieldable, dip-solder, IP67, UL, front mounting   M16 IP67 series 723 09 0132 290 12 Assembly instructions / Panel cut-out Date: 20.06.2021 Product data sheet Miniature connectors Product description   Area Order number M16 IP67 female panel mount connector, Contacts: 12, shieldable, dip-solder, IP67, UL, front mounting   M16 IP67 series 723 09 0132 290 12 Security notices The connectors have been developed for applications in plant engineering, control and electrical equipment construction. The user is responsible for checking whether the connectors can also be used in other areas of application. Plug connectors with enclosure protection IP 67 and IP 68 are not suitable for use under water. When used outdoors, the plug connectors must be protected separately against corrosion. For further information on the IP protection classes, please refer to the "Technical Information" download centre. Date: 20.06.2021
09-0132-290-12 价格&库存
很抱歉,暂时无法提供与“09-0132-290-12”相匹配的价格&库存,您可以联系我们找货
