09-3431-00-04
09-3431-00-04
    BINDER(宾德)
09-3431-00-04 数据手册
Product sheet Automation technology Product Area Male socket with wires, 0,25 mm² M12 connectors A-Coding illustration Pole Article number serie 713/763 scale drawing 4 09 3431 00 04 Contact Arrangement Installation instructions / Mounting cutout Technical data Common values Material Connector Design Male socket Connector locking system Screw-locking Termination wires Wire gauge (mm) 0,25 mm² Wire gauge (AWG) 24 Upper temperature +85 °C Lower temperature -25 °C Electrical values Rated voltage 250 V Rated impulse voltage 2500 V Pollution degree 3 Overvoltage category II Material group II Rated current (40°C) 4A Volume resistivity ≤ 3 mΩ Degree of protection IP 68 Mechanical operation >100 mating cycles Material of contact CuZn (brass) Contact plating Au (gold) Material of contact body PA Material of housing zinc diecasting, nickel plated Cable data Contacts 4: Male socket with wires, 0,25 mm², PG 9 09 3431 00 04 Powered by TCPDF (www.tcpdf.org)
09-3431-00-04 价格&库存
很抱歉,暂时无法提供与“09-3431-00-04”相匹配的价格&库存,您可以联系我们找货
    • 1+134.23436
    • 50+130.26669
    • 100+125.71584
    • 250+121.62321
    库存:116
