09-3782-95-08
09-3782-95-08
    BINDER(宾德)
    BINDER - 09-3782-95-08 - Sensor Connector, X-Coded Cable, 876 Series, M12, Female, 8 Positions, Sold...
09-3782-95-08 数据手册
Product data sheet Automation Technology Product description Contacts: 8, female connector with X-coding, dip-solder Area Order number M12-D, M12-X Series 825/876 X-coding 09 3782 95 08 Illustration Scale drawing Contact arrangement You can find the component part drawing and assembly instructions on the next page. Technical data General values Connector design Connector locking system Termination Upper limit temperature Lower limit temperature Electrical values cable connector bolted dip-solder 85 °C -40 °C Cable data Approval 1 UL Rated voltage Pollution degree Overvoltage category Insulating material group Rated current (40 °C) Volume resistivity EMC compliance Degree of protection Mechanical operation 50V AC, 60V DC V 3 II III 0,5 A ≤ 15 mΩ shielded IP67 > 100 Mating cycles Material Contact material Contact plating Contact body material CuSn (bronze) Au (gold) PA Date: 2018-02-05 - Page 1 of 4 Product data sheet Automation Technology Product description Contacts: 8, female connector with X-coding, dip-solder Area Order number M12-D, M12-X Series 825/876 X-coding 09 3782 95 08 Component part drawing Assembly instructions / Panel cut-out Date: 2018-02-05 - Page 2 of 4 Product data sheet Automation Technology Product description Contacts: 8, female connector with X-coding, dip-solder Area Order number M12-D, M12-X Series 825/876 X-coding 09 3782 95 08 Assembly instructions / Panel cut-out Date: 2018-02-05 - Page 3 of 4 Powered by TCPDF (www.tcpdf.org) Product data sheet Automation Technology Product description Contacts: 8, female connector with X-coding, dip-solder Area Order number M12-D, M12-X Series 825/876 X-coding 09 3782 95 08 Sicherheitshinweise The connectors are designed for use in plant, control system and electrical equipment. The end user is responsible for checking whether the connectors are suitable for use in other applications. Connectors with degree of protection IP 67 and IP 68 are not suitable for use under water. When used outdoors, the connectors must be separately protected against corrosion. For further information about IP degrees of protection refer to ‘Technical support’ in the Download Centre. To lock the cable connector to the equipment connector, the threaded ring is tightened until it is ‘finger-tight’ (approx. 50 cNm). Date: 2018-02-05 - Page 4 of 4
09-3782-95-08 价格&库存
很抱歉,暂时无法提供与“09-3782-95-08”相匹配的价格&库存,您可以联系我们找货
