76-4631-0011-00008-0200
    BINDER(宾德)
    BINDER - 76-4631-0011-00008-0200 - Sensor Cable, M12 Plug, Free End, 8 Positions, 200 mm, 7.9 ", 713...
76-4631-0011-00008-0200 数据手册
Product data sheet Automation technology - sensors and actuators Product description   Area Order number Illustration M12-A male panel mount connector, Contacts: 8, unshielded, single wires, IP67, UL, M20x1.5 plastic   M12-A series 763 76 4631 0011 00008-0200 Scale drawing Contact arrangement (Plug-in side) You can find the assembly instructions on the next page. Technical data General features Order number 76 4631 0011 00008-0200 Connector design male panel mount connector Wire length 0,2 m Version connector male straight Connector locking system screw Termination single wires Degree of protection IP67 Cross-sectional area 0.25 mm² / AWG 24 Temperature range from/to -40 °C / 85 °C Mechanical operation > 100 Mating cycles Weight (g) 10.822 Customs tariff number 85369010 Electrical parameters Rated voltage 30 V Rated impulse voltage 800 V Rated current (40 °C) 2 A (UL 1.5 A) Insulation resistance > 10⁸ Ω Pollution degree 3 Overvoltage category II Date: 20.06.2021 Product data sheet Automation technology - sensors and actuators Product description   Area Order number M12-A male panel mount connector, Contacts: 8, unshielded, single wires, IP67, UL, M20x1.5 plastic   M12-A series 763 76 4631 0011 00008-0200 Insulating material group III EMC compliance unshielded Material Housing material PA Contact body material PA black Contact material CuZn (brass) Contact plating Au (gold) REACH SVHC CAS 7439-92-1 (Lead) SCIP number 24dc9ecd-dd86-40ff-bcaf-2bdb7f7e111c Authorization/approvals Approvals UL Assembly instructions / Panel cut-out Date: 20.06.2021 Product data sheet Automation technology - sensors and actuators Product description   Area Order number M12-A male panel mount connector, Contacts: 8, unshielded, single wires, IP67, UL, M20x1.5 plastic   M12-A series 763 76 4631 0011 00008-0200 Security notices The connectors have been developed for applications in plant engineering, control and electrical equipment construction. The user is responsible for checking whether the connectors can also be used in other areas of application. Plug connectors with enclosure protection IP 67 and IP 68 are not suitable for use under water. When used outdoors, the plug connectors must be protected separately against corrosion. For further information on the IP protection classes, please refer to the "Technical Information" download centre. Date: 20.06.2021
PDF文档中的物料型号为:W25Q128JVSFIG。
器件简介:W25Q128JVSFIG是一款由Winbond公司生产的串行闪存存储器,具有128M位存储容量。
引脚分配:该器件共有8个引脚,包括电源、地、时钟、数据线和控制线等。
参数特性:工作电压范围为2.7V至3.6V,支持多种操作模式。
功能详解:W25Q128JVSFIG支持快速读取和写入操作,适用于需要大量数据存储和高速数据传输的应用。
应用信息:常用于嵌入式系统、工业控制和消费电子等领域。
封装信息:W25Q128JVSFIG的封装形式为SOIC-8。
76-4631-0011-00008-0200 价格&库存
很抱歉,暂时无法提供与“76-4631-0011-00008-0200”相匹配的价格&库存,您可以联系我们找货
