79-9722-020-08
79-9722-020-08
    BINDER(宾德)
    BINDER - 79-9722-020-08 - Sensor Cable, X-Coding, M12 Plug, M12 Plug, 8 Positions, 2 m, 6.6 ft
79-9722-020-08 数据手册
Powered by TCPDF (www.tcpdf.org) Product sheet Automation technology - Speciality connectors Product Cable sheath PUR, cable length 2 m, Contacts: 8, Connecting cord, 2 cable plug connectors M12x1, PUR cable, shielded Area Article number M12-D, M12-X Series 876 X-coding 79 9722 020 08 Illustration Scale drawing Contact Arrangement Technical data Common values Connector Design Connector locking system Termination Wire gauge (AWG) Upper temperature Lower temperature Electrical values Connecting cord screw crimp, injection-moulded cable 26/7 85 °C -40 °C Cable data material housing Insulation single lead Single lead structure Cable sheath Ø Conductor resistance Temperature range cable movable c from Temperature range cable movable c to Temperature range cable fixed c from Temperature range cable fixed c to Bending radius cable fixed Bending radius cable movable Approval PUR green PE 7 x 0.16 6.2 14.5Ω/100 m -10 60 -40 85 ≥ 25 mm ≥ 50 mm E 344985 Rated voltage Pollution degree Overvoltage category Material group Rated current (40°C) Volume resistivity EMV compliance Degree of protection Mechanical operation 50 V AC / 60 V DC 3 II II 0.5 A ≤ 10 mΩ geschirmt IP67 > 100 mating cycles Material Material of contact Contact plating Material of contact body Material of housing CuZn (Brass) Au (Gold) PA PUR Date: 2016-01-13 - Page 1 of 1
79-9722-020-08 价格&库存
很抱歉,暂时无法提供与“79-9722-020-08”相匹配的价格&库存,您可以联系我们找货
