99 0405 00 03
99 0405 00 03
    BINDER(宾德)
    BINDER - 99 0405 00 03 - Circular Connector, 712 Series, Cable Mount Plug, 3 Contacts, Solder Pin, N...
99 0405 00 03 数据手册
Product sheet Subminiature connectors Male cable connector M9 connectors IP 67 Pole Article number serie 712 illustration scale drawing Date: 2013-06-04 - Page 1 of 2 Product Area 3 99 0405 00 03 Contact Arrangement You can find the item description on the next page. Technical data Common values Material Connector Design Male cable connector Connector locking system Screw-locking Termination solder Wire gauge (mm) 0,25 mm² Wire gauge (AWG) 24 Max. Cable outlet 3,5 - 5 mm Upper temperature +85 °C Lower temperature -40 °C Electrical values Rated voltage 125 V Rated impulse voltage 1500 V Pollution degree 1 Overvoltage category II Material group III Rated current (40°C) 4A Volume resistivity ≤ 3 mΩ EMV compliance not shieldable Degree of protection IP 67 Mechanical operation >500 mating cycles Material of contact CuZn (brass) Contact plating Au (gold) Material of contact body PBT (UL 94 V-0) Material of housing PA (UL 94 VH-B) Cable data material housing - insulation single lead - single lead structure - conductor resistance - Contacts 3, Male cable connector Normen und Prüfbedingungen siehe Binder Katalog Seite T1-16 oder unter www.binder-connector.de 99 0405 00 03 Product sheet Subminiature connectors Male cable connector M9 connectors IP 67 serie 712 Pole Article number Date: 2013-06-04 - Page 2 of 2 Product Area 3 99 0405 00 03 Item description Normen und Prüfbedingungen siehe Binder Katalog Seite T1-16 oder unter www.binder-connector.de Powered by TCPDF (www.tcpdf.org) 99 0405 00 03
99 0405 00 03 价格&库存
很抱歉,暂时无法提供与“99 0405 00 03”相匹配的价格&库存,您可以联系我们找货
  • 1+83.35163
  • 10+81.83291
  • 100+80.31419
  • 250+78.71241
  • 500+77.11064
  • 1000+75.49700
库存:1887
