99-3361-100-03
    BINDER(宾德)
99-3361-100-03 数据手册
Product data sheet Automation technology - sensors and actuators Product description M8 cable connector, Contacts: 3, 4.0 - 5.5 mm, shieldable, screw clamp, IP67, UL listed Area Order number M8 series 768 99 3361 100 03 Illustration Scale drawing Contact arrangement You can find the component part drawing and assembly instructions on the next page. Technical data General values Connector design Connector locking system Termination Wire gauge (mm) Wire gauge (AWG) Cable outlet Upper limit temperature Lower limit temperature Customs tariff number Packaging Unit Electrical values cable connector screw screw clamp 0.14 - 0.50 mm² 26 - 20 4.0 - 5.5 mm 85 °C – 40 °C 85369010 100 4A 60 V 1500 V 3 III III shieldable IP67 > 100 Mating cycles Material Cable data Approval 1 Rated current (40 °C) Rated voltage Rated impulse voltage Pollution degree Overvoltage category Insulating material group EMC compliance Degree of protection Mechanical operation UL listed Contact material Contact plating Contact body material CuZn (brass) Au (gold) PA Date: 2020-01-19 - Page 1 of 3 Product data sheet Automation technology - sensors and actuators Product description M8 cable connector, Contacts: 3, 4.0 - 5.5 mm, shieldable, screw clamp, IP67, UL listed Area Order number M8 series 768 99 3361 100 03 Component part drawing Assembly instructions / Panel cut-out Date: 2020-01-19 - Page 2 of 3 Powered by TCPDF (www.tcpdf.org) Product data sheet Automation technology - sensors and actuators Product description M8 cable connector, Contacts: 3, 4.0 - 5.5 mm, shieldable, screw clamp, IP67, UL listed Area Order number M8 series 768 99 3361 100 03 Security notices The connectors are designed for use in plant, control system and electrical equipment. The end user is responsible for checking whether the connectors are suitable for use in other applications. Connectors with degree of protection IP 67 and IP 68 are not suitable for use under water. When used outdoors, the connectors must be separately protected against corrosion. For further information about IP degrees of protection refer to ‘Technical support’ in the Download Centre. To lock the cable connector to the equipment connector, the threaded ring is tightened until it is ‘finger-tight’ (approx. 50 cNm). Date: 2020-01-19 - Page 3 of 3
99-3361-100-03
1. 物料型号:M8系列768 99 3361 100 03,这是一个用于自动化技术的电缆连接器,具有3个接触点。
2. 器件简介:M8电缆连接器,接触点3个,适用于4.0 - 5.5 mm的电缆,可屏蔽,采用螺丝夹紧,具有IP67防护等级,并且已通过UL认证。
3. 引脚分配:文档提供了一个表格,详细列出了接触点的排列方式,包括接触点编号和距离。
4. 参数特性: - 连接器设计:螺丝夹紧 - 连接器锁定系统:螺丝锁定 - 接线规格:0.14 - 0.50 mm²,26 - 20 AWG - 电缆出口直径:4.0 - 5.5 mm - 上限温度:85°C - 下限温度:-40°C - 海关关税编号:85369010 - 包装单位:100个/包
5. 功能详解:包括电气值、额定电流、额定电压、额定脉冲电压、污染等级、过电压类别、绝缘材料组、EMC合规性和保护等级等。
6. 应用信息:连接器设计用于工业、控制系统和电气设备。最终用户负责检查连接器是否适用于其他应用。
7. 封装信息:提供了组件部件图和组装说明,以及面板切割尺寸。
8. 安全须知:指出IP67和IP68等级的连接器不适合在水下使用,如果用于户外,必须另外采取措施防护腐蚀。
99-3361-100-03 价格&库存
很抱歉,暂时无法提供与“99-3361-100-03”相匹配的价格&库存,您可以联系我们找货
  • 1+196.17587
  • 10+192.91634
  • 50+189.61515
库存:9
