Product sheet
Power connectors
Product
Area
Male cable connector with pinch ring, PG 13,5 with VDE, SEV, UL approval
RD 24 connectors
serie 693
illustration
Pole
Article number
scale drawing
3+PE
99 4221 14 04
Item description
Contact Arrangement
Technical data
Common values
Material
Connector Design
Connector locking system
Screw-locking
Termination
screw
Wire gauge (mm)
0,5-2,5 mm²
Wire gauge (AWG)
20-14
Max. Cable outlet
10 - 12 mm
Upper temperature
+100 °C
Lower temperature
-40 °C
Material of contact
CuZn (brass)
Contact plating
Ag (silver)
Material of contact body
PBT (UL 94 V-0)
Material of housing
PBT (UL 94 V 0)
Cable data
Contacts 3+PE, male cable connector with
approval, screw
Electrical values
Rated voltage
600 V
Rated impulse voltage
6000 V
Pollution degree
3
Overvoltage category
III
Material group
III
Rated current (40°C)
12 A
Volume resistivity
≤ 5 mΩ
EMV compliance
not shielded
Degree of protection
IP 67
Mechanical operation
>500 mating cycles
99 4221 14 04
Powered by TCPDF (www.tcpdf.org)
很抱歉,暂时无法提供与“99-4221-14-04”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+127.50702
- 10+123.92466
- 50+119.84244
- 100+117.30146
- 250+114.75007
- 国内价格
- 10+123.92466
- 50+119.84244
- 100+117.30146
- 250+114.75007
