99-4222-00-04
99-4222-00-04
    BINDER(宾德)
99-4222-00-04 数据手册
Product data sheet Power connectors Product description RD24 female cable connector, Contacts: 3+PE, 6.0 - 9.5 mm, shielding is not possible, screw clamp, IP67, UL, ESTI+, VDE, PG9 Area Order number RD24 series 693 99 4222 00 04 Illustration Scale drawing Contact arrangement Derating curve You can find the component part drawing and assembly instructions on the next page. Technical data General values Connector design Connector locking system Termination Wire gauge (mm) Wire gauge (AWG) Cable outlet Upper limit temperature Lower limit temperature Customs tariff number Packaging Unit Electrical values female cable connector screw screw clamp max. 2.50 mm² max. 14 6.0 - 9.5 mm 100 °C – 40 °C 85369010 40 Degree of protection 2 Mechanical operation Cable data Approval 1 Approval 2 Approval 3 Rated current (40 °C) Rated voltage Rated voltage UL Rated impulse voltage Pollution degree Overvoltage category Insulating material group Insulation resistance EMC compliance Degree of protection UL ESTI+ VDE 16 A (12 A UL) 400 (UL 600 V) V 600 6000 V 3 III III ≥ 10¹⁰ Ω shielding is not possible IP67 IP65 with cable diameter 6-7 mm IP65 with cable diameter 6-7 mm > 500 Mating cycles Material Contact material Contact plating Contact body material CuZn (brass) Ag (silver) PBT (UL94 V-0) Date: 2020-01-19 - Page 1 of 3 Product data sheet Power connectors Product description RD24 female cable connector, Contacts: 3+PE, 6.0 - 9.5 mm, shielding is not possible, screw clamp, IP67, UL, ESTI+, VDE, PG9 Area Order number RD24 series 693 99 4222 00 04 Component part drawing Assembly instructions / Panel cut-out Date: 2020-01-19 - Page 2 of 3 Powered by TCPDF (www.tcpdf.org) Product data sheet Power connectors Product description RD24 female cable connector, Contacts: 3+PE, 6.0 - 9.5 mm, shielding is not possible, screw clamp, IP67, UL, ESTI+, VDE, PG9 Area Order number RD24 series 693 99 4222 00 04 Security notices The connector must not be connected or separated under load. Non-observance and incorrect use can result in personal injury. The connectors are designed for use in plant, control system and electrical equipment. The end user is responsible for checking whether the connectors are suitable for use in other applications. To prevent the connector being opened unintentionally when used in electrical circuits containing hazardous life parts, the thread between the housing and the connector head must be secured using a suitable cyanoacrylate adhesive. This does not apply to connectors used in SELV and PELV circuits according to IEC 61140 (EN 61140, VDE 0140-1). Connectors used in electrical circuits containing hazardous life parts must only be assembled and used by or under the supervision of persons with the requisite electrotechnical training, taking the applicable regulations and standards into account. The end user must take suitable safety measures to ensure that the connector cannot be disconnected accidentally. Connectors with degree of protection IP 67 and IP 68 are not suitable for use under water. When used outdoors, the connectors must be separately protected against corrosion. For further information about IP degrees of protection refer to ‘Technical support’ in the Download Centre. To lock the cable connector to the equipment connector, the threaded ring is tightened until it is ‘finger-tight’ (approx. 50 cNm). Date: 2020-01-19 - Page 3 of 3
99-4222-00-04 价格&库存
很抱歉,暂时无法提供与“99-4222-00-04”相匹配的价格&库存,您可以联系我们找货
