08-0352-000-001
08-0352-000-001
    BINDER(宾德)
08-0352-000-001 数据手册
Powered by TCPDF (www.tcpdf.org) Accessory data sheet Product description Protection cap for female panel mount connector Order number 08 0352 000 001 Illustration Scale drawing Technical data Degree of protection IP67 Matching products 09 0404 00 02 - Female panel mount connector, solder 09 0408 00 03 - Female panel mount connector, solder 09 0412 00 04 - Female panel mount connector, solder 09 0416 00 05 - Female panel mount connector, solder 09 0424 00 07 - Female panel mount connector, solder 09 0428 00 08 - Female panel mount connector, solder 09 0404 80 02 - Female panel mount connector, solder, screwed from front 09 0408 80 03 - Female panel mount connector, solder, screwed from front 09 0412 80 04 - Female panel mount connector, solder, screwed from front 09 0416 80 05 - Female panel mount connector, solder, screwed from front 09 0424 80 07 - Female panel mount connector, solder, screwed from front 09 0428 80 08 - Female panel mount connector, solder, screwed from front 09 0404 90 02 - Female panel mount connector, dip-solder, screwed from front 09 0408 90 03 - Female panel mount connector, dip-solder, screwed from front 09 0412 90 04 - Female panel mount connector, dip-solder, screwed from front 09 0416 90 05 - Female panel mount connector, dip-solder, screwed from front 09 0424 90 07 - Female panel mount connector, dip-solder, screwed from front 09 0428 90 08 - Female panel mount connector, dip-solder, screwed from front 09 0404 30 02 - Female panel mount connector, dip-solder, screwed from front with shielding sheet (6 mm) 09 0408 30 03 - Female panel mount connector, dip-solder, screwed from front with shielding sheet (6 mm) 09 0412 30 04 - Female panel mount connector, dip-solder, screwed from front with shielding sheet (6 mm) 09 0416 30 05 - Female panel mount connector, dip-solder, screwed from front with shielding sheet (6 mm) 09 0424 30 07 - Female panel mount connector, dip-solder, screwed from front with shielding sheet (6 mm) 09 0428 30 08 - Female panel mount connector, dip-solder, screwed from front with shielding sheet (6 mm) 09 0404 35 02 - Female panel mount connector, dip-solder, screwed from front with shielding sheet (10 mm) 09 0408 35 03 - Female panel mount connector, dip-solder, screwed from front with shielding sheet (10 mm) 09 0412 35 04 - Female panel mount connector, dip-solder, screwed from front with shielding sheet (10 mm) 09 0416 35 05 - Female panel mount connector, dip-solder, screwed from front with shielding sheet (10 mm) 09 0424 35 07 - Female panel mount connector, dip-solder, screwed from front with shielding sheet (10 mm) 09 0428 35 08 - Female panel mount connector, dip-solder, screwed from front with shielding sheet (10 mm) 09 0404 55 02 - Female panel mount connector, dip-solder, screwed from front with shielding sheet, angled 09 0416 55 05 - Female panel mount connector, dip-solder, screwed from front with shielding sheet, angled 09 0424 65 07 - Female panel mount connector with flexible printed circuit board (PCB), contacts 7 09 0428 65 08 - Female panel mount connector with flexible printed circuit board (PCB), contacts 8 Date: 2018-02-05 - Page 1 of 1
08-0352-000-001 价格&库存
很抱歉,暂时无法提供与“08-0352-000-001”相匹配的价格&库存,您可以联系我们找货
    • 1+32.49118
    • 15+32.07462
    • 50+30.54379
    • 100+29.89813
    • 250+29.24206
    库存:514
