08-2636-400-001
08-2636-400-001
    BINDER(宾德)
    BINDER - 08-2636-400-001 - Connector Accessory, Adaptor, Binder 620 Series Circular Connectors, 620 ...
08-2636-400-001 数据手册
Product data sheet Connectors for medical applications Product description Adaptor for panel mount connector Area Order number Snap-in IP67, subminiature Series 620 MED 08 2636 400 001 Illustration Scale drawing You can find the component part drawing and assembly instructions on the next page. Technical data General values Connector design Connector locking system Termination Electrical values adapter snap plugable Pollution degree 2 Material Contact body material PA (UL 94 V-0) Date: 2018-11-22 - Page 1 of 4 Product data sheet Connectors for medical applications Product description Adaptor for panel mount connector Area Order number Snap-in IP67, subminiature Series 620 MED 08 2636 400 001 Component part drawing Assembly instructions / Panel cut-out Date: 2018-11-22 - Page 2 of 4 Product data sheet Connectors for medical applications Product description Adaptor for panel mount connector Area Order number Snap-in IP67, subminiature Series 620 MED 08 2636 400 001 Assembly instructions / Panel cut-out Date: 2018-11-22 - Page 3 of 4 Powered by TCPDF (www.tcpdf.org) Product data sheet Connectors for medical applications Product description Adaptor for panel mount connector Area Order number Snap-in IP67, subminiature Series 620 MED 08 2636 400 001 Security notices The connector must not be connected or separated under load. Non-observance and incorrect use can result in personal injury. The connectors are designed for use in plant, control system and electrical equipment. The end user is responsible for checking whether the connectors are suitable for use in other applications. Date: 2018-11-22 - Page 4 of 4
08-2636-400-001 价格&库存
很抱歉,暂时无法提供与“08-2636-400-001”相匹配的价格&库存,您可以联系我们找货
