09 0077 00 03
09 0077 00 03
    BINDER(宾德)
09 0077 00 03 数据手册
Product sheet Subminiature connectors Product Area Male socket, solder M9 connectors IP 40 Pole Article number serie 711 illustration scale drawing 3 09 0077 00 03 Contact Arrangement Installation instructions / Mounting cutout Technical data Common values Material Connector Design Male socket Connector locking system Screw-locking Termination solder Wire gauge (mm) 0,25 mm² Wire gauge (AWG) 24 Max. Cable outlet - Upper temperature +85 °C Lower temperature -40 °C Electrical values Rated voltage 125 V Rated impulse voltage 1500 V Pollution degree 1 Overvoltage category II Material group III Rated current (40°C) 4A Volume resistivity ≤ 3 mΩ EMV compliance not shieldable Degree of protection IP 40 Mechanical operation >500 mating cycles Material of contact CuZn (brass) Contact plating Au (gold) Material of contact body PA (UL 94 V-0) Material of housing CUZn (brass nickel plated) Cable data material housing - insulation single lead - single lead structure - conductor resistance - Contacts 3, Male socket, solder 09 0077 00 03 Powered by TCPDF (www.tcpdf.org)
09 0077 00 03 价格&库存
很抱歉,暂时无法提供与“09 0077 00 03”相匹配的价格&库存,您可以联系我们找货
