Product sheet
Miniature connectors
Female socket, solder
M16 connectors IP 40
Pole
Article number
serie 581/ 680/ 682
illustration
scale drawing
Date: 2013-05-16 - Page 1 of 1
Product
Area
5
09 0316 00 05
Contact Arrangement
Technical data
Common values
Material
Connector Design
Female socket
Connector locking system
Screw-locking
Termination
solder
Wire gauge (mm)
0,75 mm²
Wire gauge (AWG)
Max. Cable outlet
Upper temperature
+85 °C
Lower temperature
-40 °C
Material of contact
CuSn (bronce)
Contact plating
Ag (silver)
Material of contact body
PBT (UL 94 V-0)
Material of housing
zinc diecasting, nickel plated
Cable data
Contacts 5, female socket, solder, 2 – 8
Contacts, silver plated contacts
Electrical values
Rated voltage
250 V
Rated impulse voltage
1500 V
Pollution degree
1
Overvoltage category
I
Material group
III
Rated current (40°C)
6A
Volume resistivity
≤ 5 mΩ
EMV compliance
shielded
Degree of protection
IP 40
Mechanical operation
>500 mating cycles
Normen und Prüfbedingungen siehe Binder Katalog Seite T1-16 oder unter www.binder-connector.de
Powered by TCPDF (www.tcpdf.org)
09 0316 00 05
很抱歉,暂时无法提供与“09 0316 00 05”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+63.240931+8.15860
- 5+56.846765+7.33370
- 20+50.5401920+6.52010
- 100+44.23361100+5.70650
