09-0111-782-04
09-0111-782-04
    BINDER(宾德)
    BINDER - 09-0111-782-04 - CIRCULAR CONNECTOR, PLUG, 4POS, PANEL
09-0111-782-04 数据手册
Product data sheet Miniature connectors Product description   Area Order number Illustration M16 IP67 male panel mount connector, Contacts: 4, unshielded, single wires, IP67, UL, front mounting   M16 IP67 series 723 09 0111 782 04 Scale drawing Contact arrangement (Plug-in side) You can find the assembly instructions on the next page. Technical data General features Order number 09 0111 782 04 Connector design male panel mount connector Version connector male straight Connector locking system screw Termination single wires Degree of protection IP67 Cross-sectional area AWG 22 Temperature range from/to -30 °C / 85 °C Mechanical operation > 500 Mating cycles Weight (g) 15.986 Customs tariff number 85369010 Electrical parameters Rated voltage 300 V Rated impulse voltage 1500 V Rated current (40 °C) 5A Insulation resistance ≥ 10¹⁰ Ω Pollution degree 1 Overvoltage category I Insulating material group II EMC compliance unshielded Date: 12.06.2021 Product data sheet Miniature connectors Product description   Area Order number M16 IP67 male panel mount connector, Contacts: 4, unshielded, single wires, IP67, UL, front mounting   M16 IP67 series 723 09 0111 782 04 Material Housing material Zinc die-cast nickel-plated Contact body material PBT (UL94 V-0) Contact material CuSn (bronze) Contact plating Ag (silver) REACH SVHC CAS 7439-92-1 (Lead) Authorization/approvals Approvals UL Date: 12.06.2021 Product data sheet Miniature connectors Product description   Area Order number M16 IP67 male panel mount connector, Contacts: 4, unshielded, single wires, IP67, UL, front mounting   M16 IP67 series 723 09 0111 782 04 Date: 12.06.2021 Product data sheet Miniature connectors Product description   Area Order number M16 IP67 male panel mount connector, Contacts: 4, unshielded, single wires, IP67, UL, front mounting   M16 IP67 series 723 09 0111 782 04 Date: 12.06.2021 Product data sheet Miniature connectors Product description   Area Order number M16 IP67 male panel mount connector, Contacts: 4, unshielded, single wires, IP67, UL, front mounting   M16 IP67 series 723 09 0111 782 04 Assembly instructions / Panel cut-out Date: 12.06.2021 Product data sheet Miniature connectors Product description   Area Order number M16 IP67 male panel mount connector, Contacts: 4, unshielded, single wires, IP67, UL, front mounting   M16 IP67 series 723 09 0111 782 04 Security notices The connector must not be plugged or unplugged under load. Non-observance and improper use can result in personal injury. The connectors have been developed for applications in plant engineering, control and electrical equipment construction. The user is responsible for checking whether the connectors can also be used in other areas of application. Plug connectors with enclosure protection IP 67 and IP 68 are not suitable for use under water. When used outdoors, the plug connectors must be protected separately against corrosion. For further information on the IP protection classes, please refer to the "Technical Information" download centre. Date: 12.06.2021
09-0111-782-04 价格&库存
很抱歉,暂时无法提供与“09-0111-782-04”相匹配的价格&库存,您可以联系我们找货
