09-0428-00-08
09-0428-00-08
    BINDER(宾德)
09-0428-00-08 数据手册
Product data sheet Subminiature connectors Product description   Area Part no. Illustration M9 Female panel mount connector, Contacts: 8, unshielded, solder, IP67   M9 IP67 09 0428 00 08 Scale drawing Contact arrangement (Plug-in side) You can find the component part drawing and assembly instructions on the next page. Technical data General features Part no. Connector design Version Connector locking system Termination Degree of protection Cross-sectional area Temperature range from/to Mechanical operation Weight (g) Customs tariff number Country of Origin 09 0428 00 08 Female panel mount connector Connector socket straight screw solder IP67 0.14 mm² / AWG 26 -40 °C / 85 °C > 500 Mating cycles 5.19 85369010 DE Electrical parameters Rated voltage Rated impulse voltage Rated current Insulation resistance Pollution degree Overvoltage category Insulating material group EMC compliance 125 V 1500 V 1.0 A ≥ 1010 Ω 1 II III unshielded Date: 29.05.2024 Product data sheet Subminiature connectors Product description   Area Part no. M9 Female panel mount connector, Contacts: 8, unshielded, solder, IP67   M9 IP67 09 0428 00 08 Material Contact body material Contact material Contact plating REACH SVHC SCIP number PA (UL94 V-0) CuSn (bronze) Au (gold) CAS 7439-92-1 (Lead) cf5f60eb-90f2-46df-8690-0cea74782892 Classifications eCl@ss 11.1 ETIM 9.0 27-44-01-09 EC003569 Assembly instructions / Panel cut-out Date: 29.05.2024 Product data sheet Subminiature connectors Product description   Area Part no. M9 Female panel mount connector, Contacts: 8, unshielded, solder, IP67   M9 IP67 09 0428 00 08 Component part drawing Date: 29.05.2024 Product data sheet Subminiature connectors Product description   Area Part no. M9 Female panel mount connector, Contacts: 8, unshielded, solder, IP67   M9 IP67 09 0428 00 08 Security notices The connector must not be plugged or unplugged under load. Non-observance and improper use can result in personal injury. The connectors have been developed for applications in plant engineering, control and electrical equipment construction. The user is responsible for checking whether the connectors can also be used in other areas of application. Plug connectors with enclosure protection IP67 and IP68 are not suitable for use under water. When used outdoors, the plug connectors must be protected separately against corrosion. For further information on the IP protection classes, please refer to the "Technical Information" download centre. Date: 29.05.2024 DECLARATION FROM THE MANUFACTURER For part no.: 09 0428 00 08 29/05/2024 With regard to the Regulation (EC) No 1907/2006 of the European Parliament and of the Council of 18 December 2006 concerning the Registration, Evaluation, Authorisation and Restriction of Chemicals (REACH), establishing a European Chemicals Agency, amending Directive 1999/45/EC and repealing Council Regulation (EEC) No 793/93 and Commission Regulation (EC) No 1488/94 as well as Council Directive 76/769/EEC and Commission Directives 91/155/EEC, 93/67/EEC, 93/105/EC and 2000/21/EC. With the REACH regulation, the EU has created a uniform system for the Registration, Evaluation, Authorisation and restriction of CHemicals – or REACH. The purpose of this regulation is to ensure a high level of protection of human health and the environment. Franz Binder GmbH & Co. Elektrische Bauelemente KG hereby confirms that it acts as a downstream user (producer of products) according to the aforementioned regulation. We obtain all raw materials and/or preparations, from which the connectors are made, from suppliers who have already registered or pre-registered all substances, including those present in the preparations. The products supplied by the company are not subject to registration. With regard to Article 33(1) of the REACH regulation, Franz Binder GmbH & Co. Elektrische Bauelemente KG complies with its information obligations: An up-to-date candidate list (candidate list of substances of very high concern for authorisation, as of 23/01/2024 see: https://echa.europa.eu/de/candidate-list-table) in accordance with Article 59 (1, 10) of the regulation (EC) No 1907/2006 (REACH) has been published. The aforementioned article includes the following substances from the up-to-date candidate list in concentrations of more than 0,1 percent by mass: CAS 7439-92-1 (Lead) Please refer any questions to our Product Compliance Team: Product-Compliance@binder-connector.de Franz Binder GmbH & Co. Elektrische Bauelemente KG Postfach 1152 • 74148 Neckarsulm Rötelstraße 27 • 74172 Neckarsulm Phone +49 7132 325-0 Fax +49 7132 325-150 info@binder-connector.de www.binder-connector.com Date: 29/05/2024 DECLARATION FROM THE MANUFACTURER For part no.: 09 0428 00 08 29/05/2024 With regard to the COMMISSION DELEGATED DIRECTIVE (EU) 2015/863 of 31 March 2015 amending Annex II to Directive 2011/65/EU of the European Parliament and of the Council as regards the list of restricted substances Directive 2011/65/EU stipulates provisions on the restriction of the use of hazardous substances in electrical and electronic equipment (EEE) with a view to contributing to the protection of human health and the environment, including the environmentally sound recovery and disposal of EEE waste. ANNEX II Restricted substances referred to in Article 4(1) and maximum concentration values tolerated by weight in homogeneous materials Lead (0,1%) mercury (0,1%) cadmium (0,01%) hexavalent chromium (0,1%) polybrominated biphenyls (PBB) (0,1%) polybrominated diphenyl ethers (PBDE) (0,1%) bis(2-ethylhexyl) phthalate (DEHP) (0,1%) butyl benzyl phthalate (BBP) (0,1%) dibutyl phthalate (DBP) (0,1%) diisobutyl phthalate (DIBP) (0,1%) Franz Binder GmbH & Co. Elektrische Bauelemente KG hereby confirms that it complies with all standard articles of the aforementioned Directive. Our products do not contain any of the specified prohibited substances above the maximum permitted concentrations specified therein, taking into account the exemptions in Annex III of Directive 2011/65/EU. Complies with RoHS III with exemption 6c Please refer any questions to our Product Compliance Team: Product-Compliance@binder-connector.de Franz Binder GmbH & Co. Elektrische Bauelemente KG Postfach 1152 • 74148 Neckarsulm Rötelstraße 27 • 74172 Neckarsulm Phone +49 7132 325-0 Fax +49 7132 325-150 info@binder-connector.de www.binder-connector.com Date: 29/05/2024 MANUFACTURER’S DECLARATION For part no.: 09 0428 00 08 29/05/2024 with regard to Declaration of compliance with China RoHS – Components We herewith declare the compliance of this product with the Chinese marking requirements. This product can be recycled and used safely during its environmentally friendly use period of 50 years. These articles will be sold as components only for manufacturing. According to the Electronic Industry Standard SJ/T 11364-2014 it needs not to be marked with Environmentally Friendly Use Period (EFUP) label. This product should be recycled after its environmental protection use period has expired because it may contain substances or elements as shown in the following table: Hazardous Substance Part Name Lead (Pb) Mercury (Hg) Cadmium (Cd) Connectors X O O Hexavalent Polybrominated Polybrominated Chromium biphenyls diphenyl (Cr(VI)) (PBB) ethers (PBDE) O O O This table is prepared in accordance with the provisions of SJ/T 11364. O: Indicates that said hazardous substance contained in all of the homogeneous materials for this part is below the limit requirement of GB/T 26572 X: Indicates that said hazardous substance contained in at least one of the homogeneous materials used for this part is above the limit requirement of GB/T 26572 The table shows where these substances may be found in this Electrical and Electronic Product. Please refer any questions to our Product Compliance Team: Product-Compliance@binder-connector.de Franz Binder GmbH & Co. Elektrische Bauelemente KG Postfach 1152 • 74148 Neckarsulm Rötelstraße 27 • 74172 Neckarsulm Powered by TCPDF (www.tcpdf.org) Phone +49 7132 325-0 Fax +49 7132 325-150 info@binder-connector.de www.binder-connector.com Date: 29/05/2024
09-0428-00-08 价格&库存
很抱歉,暂时无法提供与“09-0428-00-08”相匹配的价格&库存,您可以联系我们找货
