Powered by TCPDF (www.tcpdf.org)
Product sheet
Automation technology - Speciality connectors
Product
Contacts: 8, Contacts: 8, Female panel mount connector with X-coding, screwed from front, dip-solder
Area
Article number
M12-D, M12-X Series 825/876 X-coding
09 3782 91 08
Illustration
Conductor layout
Scale drawing
Contact Arrangement
Technical data
Common values
Connector Design
Connector locking system
Termination
Upper temperature
Lower temperature
Electrical values
Cable plug connector
screw
dip-solder
85 °C
-40 °C
Cable data
material housing
Insulation single lead
Single lead structure
Conductor resistance
Bending radius cable fixed
Bending radius cable movable
Rated voltage
Pollution degree
Overvoltage category
Material group
Rated current (40°C)
Volume resistivity
Degree of protection
Mechanical operation
50 V AC / 60 V DC
3
II
III
0.5 A
≤ 10 mΩ
IP67
> 100 mating cycles
Material
Material of contact
Contact plating
Material of contact body
Material of housing
CuSn (Bronze)
Au (Gold)
PA
Nickel-plated zinc die casting
Date: 2016-01-13 - Page 1 of 1
很抱歉,暂时无法提供与“09-3782-91-08”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+193.68426
- 10+192.14181
- 25+186.42288
- 100+181.66502
- 250+176.18339
- 500+167.71178
