Product sheet
Subminiature connectors
Product
Area
Female cable connector
M9 connectors IP 67
Pole
Article number
serie 712
illustration
scale drawing
Contact Arrangement
Installation instructions / Mounting cutout
7
99 0422 00 07
Item description
Technical data
Common values
Material
Connector Design
Connector locking system
Screw-locking
Termination
solder
Wire gauge (mm)
0,14 mm²
Wire gauge (AWG)
26
Max. Cable outlet
3,5 - 5 mm
Upper temperature
+85 °C
Lower temperature
-40 °C
Electrical values
Rated voltage
125 V
Rated impulse voltage
1500 V
Pollution degree
1
Overvoltage category
II
Material group
III
Rated current (40°C)
1A
Volume resistivity
≤ 3 mΩ
EMV compliance
not shieldable
Degree of protection
IP 67
Mechanical operation
>500 mating cycles
Material of contact
CuSn (bronce)
Contact plating
Au (gold)
Material of contact body
PA (UL 94 V-0)
Material of housing
PA (UL 94 V-0)
Cable data
material housing
insulation single lead
single lead structure
conductor resistance
Contacts 7, Female cable connector
99 0422 00 07
Powered by TCPDF (www.tcpdf.org)
很抱歉,暂时无法提供与“99 0422 00 07”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+173.055161+22.45310
- 5+155.636425+20.19310
- 20+138.4789620+17.96700
- 100+121.06023100+15.70700
