99 9113 00 05
99 9113 00 05
    BINDER(宾德)
    BINDER - 99 9113 00 05 - Circular Connector, 720 Series, Cable Mount Plug, 5 Contacts, Solder Pin, N...
99 9113 00 05 数据手册
Product sheet Miniature connectors Male cable connector black, cable outlet 4-6 mm Snap-in connectors IP 67 serie 720 illustration Pole Article number scale drawing Date: 2013-11-06 - Page 1 of 2 Product Area 5 99 9113 00 05 Contact Arrangement You can find the item description on the next page. Technical data Common values Material Connector Design Male cable connector Connector locking system Snap-in locking Termination solder Wire gauge (mm) 0,75 mm² Wire gauge (AWG) 20 Cable outlet 4 - 6 mm Upper temperature +85 °C Lower temperature -40 °C Material of contact CuZn (brass) Contact plating Au (gold) Material of contact body PA (UL 94 V-0) Material of housing PA (UL 94 V-0) Cable data Contacts 5, male cable connector, black, cable outlet 4 – 6 mm Electrical values Rated voltage 125 V Rated impulse voltage 1500 V Pollution degree 2 Overvoltage category II Material group II Rated current (40°C) 5A Volume resistivity ≤ 3 mΩ EMV compliance not shielded Degree of protection IP 67 Mechanical operation >500 mating cycles Normen und Prüfbedingungen siehe Binder Katalog Seite T1-16 oder unter www.binder-connector.de 99 9113 00 05 Product sheet Miniature connectors Male cable connector black, cable outlet 4-6 mm Snap-in connectors IP 67 serie 720 Pole Article number Date: 2013-11-06 - Page 2 of 2 Product Area 5 99 9113 00 05 Item description Normen und Prüfbedingungen siehe Binder Katalog Seite T1-16 oder unter www.binder-connector.de Powered by TCPDF (www.tcpdf.org) 99 9113 00 05
99 9113 00 05
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款光耦器件。
2. 器件简介:EL817是一种通用型晶体管输出光耦器件,具有较高的输入输出隔离电压和快速响应时间。
3. 引脚分配:EL817共有8个引脚,其中1脚为发光二极管阳极,2脚为发光二极管阴极,3-6脚为晶体管输出部分,7脚为晶体管集电极,8脚为晶体管发射极。
4. 参数特性:EL817的主要参数包括输入电流为10mA,输出电流为30mA,隔离电压为5000V,响应时间为1us。
5. 功能详解:EL817通过光电效应实现电信号的隔离传输,常用于开关电源、信号隔离等应用。
6. 应用信息:EL817适用于需要电隔离的各种应用场合,如开关电源、信号隔离、工业控制等。
7. 封装信息:EL817采用DIP8封装形式,具有较好的散热性能和稳定性。
99 9113 00 05 价格&库存
很抱歉,暂时无法提供与“99 9113 00 05”相匹配的价格&库存,您可以联系我们找货
  • 1+88.223301+11.44690
  • 5+79.427105+10.30560
  • 20+70.6309020+9.16430
  • 100+61.83469100+8.02300
库存:175
