99-5622-15-06
99-5622-15-06
    BINDER(宾德)
99-5622-15-06 数据手册
Product data sheet Miniature connectors Product description M16 IP67 female cable connector, Contacts: 6 DIN, 6.0 - 8.0 mm, shieldable, solder, IP67, UL Area Order number M16 IP67 series 423 99 5622 15 06 Illustration Scale drawing Contact arrangement You can find the component part drawing and assembly instructions on the next page. Technical data General values Connector design Connector locking system Termination Wire gauge (mm) Wire gauge (AWG) Cable outlet Upper limit temperature Lower limit temperature Customs tariff number Packaging Unit Electrical values female cable connector screw solder 0.75 mm² 18 6.0 - 8.0 mm 95 °C – 30 °C 85369010 30 Cable data Approval 1 Rated current (40 °C) Rated voltage Rated impulse voltage Pollution degree Overvoltage category Insulating material group Insulation resistance EMC compliance Degree of protection Mechanical operation 5A 250 V 1500 V 1 I III ≥ 10¹⁰ Ω shieldable IP67 > 500 Mating cycles Material UL Contact material Contact plating Contact body material CuSn (bronze) Ag (silver) PBT (UL94 V-0) Date: 2020-01-18 - Page 1 of 3 Product data sheet Miniature connectors Product description M16 IP67 female cable connector, Contacts: 6 DIN, 6.0 - 8.0 mm, shieldable, solder, IP67, UL Area Order number M16 IP67 series 423 99 5622 15 06 Component part drawing Assembly instructions / Panel cut-out Date: 2020-01-18 - Page 2 of 3 Powered by TCPDF (www.tcpdf.org) Product data sheet Miniature connectors Product description M16 IP67 female cable connector, Contacts: 6 DIN, 6.0 - 8.0 mm, shieldable, solder, IP67, UL Area Order number M16 IP67 series 423 99 5622 15 06 Security notices The connector must not be connected or separated under load. Non-observance and incorrect use can result in personal injury. The connectors are designed for use in plant, control system and electrical equipment. The end user is responsible for checking whether the connectors are suitable for use in other applications. Connectors used in electrical circuits containing hazardous life parts must only be assembled and used by or under the supervision of persons with the requisite electrotechnical training, taking the applicable regulations and standards into account. Connectors with degree of protection IP 67 and IP 68 are not suitable for use under water. When used outdoors, the connectors must be separately protected against corrosion. For further information about IP degrees of protection refer to ‘Technical support’ in the Download Centre. The connector is not suitable for mains voltages. Please observe the pollution degrees and the overvoltage category. For further information refer to ‘Technical support’ in the Download Centre. To lock the cable connector to the equipment connector, the threaded ring is tightened until it is ‘finger-tight’ (approx. 50 cNm). Date: 2020-01-18 - Page 3 of 3
99-5622-15-06
1. 物料型号:M16 IP67 系列,423 99 5622 15 06。 2. 器件简介:这是一种M16 IP67标准的母头电缆连接器,具有6个DIN接触点,适用于6.0 - 8.0 mm的电缆,可屏蔽,采用焊接方式连接,符合IP67防护等级,并通过UL认证。 3. 引脚分配:提供了一个表格,展示了6个接触点的位置和尺寸。 4. 参数特性: - 额定电流(40°C):5A - 额定电压:250V(交流),1500V(脉冲) - 接触材料:CuSn(青铜)和Ag(银) - 绝缘材料:PBT(UL94 V-0) - 屏蔽:可屏蔽 - 温度范围:-30°C 至 95°C - 污染等级和过电压类别:III - 绝缘电阻:≥ 10^10 Ω 5. 功能详解:包括组件部分图纸和组装说明,如螺纹环、耦合环、密封圈等部件的详细描述。 6. 应用信息:连接器设计用于工业、控制系统和电气设备。文档强调了连接器的正确使用和安全注意事项。 7. 封装信息:提供了产品的安全警告和使用限制,例如不适用于带电操作、不适用于水下使用、不适用于户外无额外防护的情况等。
99-5622-15-06 价格&库存
很抱歉,暂时无法提供与“99-5622-15-06”相匹配的价格&库存,您可以联系我们找货
