99-9209-400-04
99-9209-400-04
    BINDER(宾德)
    BINDER - 99-9209-400-04 - Circular Connector, 620 Series, Cable Mount Plug, 4 Contacts, Solder Pin, ...
99-9209-400-04 数据手册
Product data sheet Connectors for medical applications Product description Contacts: 4, cable plug connector Area Order number Snap-in IP67, subminiature Series 620 MED 99 9209 400 04 Illustration Scale drawing Contact arrangement You can find the component part drawing on the next page. Technical data General values Connector design Connector locking system Termination Wire gauge (mm) Wire gauge (AWG) Cable outlet Upper limit temperature Lower limit temperature Electrical values cable connector snap solder 0,25 mm² 24 3,0 - 5,0 mm 85 °C -25 °C Rated current (40 °C) Rated voltage Rated impulse voltage Pollution degree Overvoltage category Insulating material group Volume resistivity Insulation resistance EMC compliance Degree of protection 2,5 A 125 V 1500 V 2 II II ≤ 3 mΩ ≥ 10¹⁰Ω Shielding is not possible IP67 Material Contact material Contact plating Contact body material Housing material CuZn (brass) Au (gold) PA (UL 94 V-0) PA Date: 2018-11-22 - Page 1 of 3 Product data sheet Connectors for medical applications Product description Contacts: 4, cable plug connector Area Order number Snap-in IP67, subminiature Series 620 MED 99 9209 400 04 Component part drawing Date: 2018-11-22 - Page 2 of 3 Powered by TCPDF (www.tcpdf.org) Product data sheet Connectors for medical applications Product description Contacts: 4, cable plug connector Area Order number Snap-in IP67, subminiature Series 620 MED 99 9209 400 04 Security notices The connector must not be connected or separated under load. Non-observance and incorrect use can result in personal injury. The connectors are designed for use in plant, control system and electrical equipment. The end user is responsible for checking whether the connectors are suitable for use in other applications. To prevent the connector being opened unintentionally when used in electrical circuits containing hazardous life parts, the thread between the housing and the connector head must be secured using a suitable cyanoacrylate adhesive. This does not apply to connectors used in SELV and PELV circuits according to IEC 61140 (EN 61140, VDE 0140-1). Connectors used in electrical circuits containing hazardous life parts must only be assembled and used by or under the supervision of persons with the requisite electrotechnical training, taking the applicable regulations and standards into account. Connectors with degree of protection IP 67 and IP 68 are not suitable for use under water. When used outdoors, the connectors must be separately protected against corrosion. For further information about IP degrees of protection refer to ‘Technical support’ in the Download Centre. Date: 2018-11-22 - Page 3 of 3
99-9209-400-04
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路不受外部干扰。
3. 引脚分配:EL817共有6个引脚,分别为1脚阳极,2脚阴极,3脚发光二极管正极,4脚发光二极管负极,5脚集电极,6脚发射极。
4. 参数特性:工作温度范围为-55℃至125℃,隔离电压为5000Vrms。
5. 功能详解:EL817通过光电效应实现信号传输,输入端控制发光二极管发光,光敏三极管导通输出信号。
6. 应用信息:广泛应用于工业控制、仪器仪表、医疗设备等领域。
7. 封装信息:采用DIP6封装形式。
99-9209-400-04 价格&库存
很抱歉,暂时无法提供与“99-9209-400-04”相匹配的价格&库存,您可以联系我们找货
