09 9766 30 04
09 9766 30 04
    BINDER(宾德)
    BINDER - 09 9766 30 04 - Circular Connector, 709 Series, Panel Mount Receptacle, 4 Contacts, Solder ...
09 9766 30 04 数据手册
Product sheet Subminiature connectors Female socket, solder termination Snap-in connectors IP 40 illustration Pole Article number serie 709/719 scale drawing Date: 2013-07-15 - Page 1 of 2 Product Area 4 09 9766 30 04 Contact Arrangement You can find the item description and assembly instruction on the next page. Technical data Common values Material Connector Design Female socket Connector locking system Snap-in locking Termination solder Wire gauge (mm) 0,25 mm² Wire gauge (AWG) 24 Max. Cable outlet - Upper temperature +70 °C Lower temperature -25 °C Electrical values Rated voltage 60 V Rated impulse voltage 800 V Pollution degree 1 Overvoltage category II Material group III Rated current (40°C) 3A Volume resistivity ≤ 3 mΩ EMV compliance not shieldable Degree of protection IP 40 Mechanical operation >100 mating cycles Material of contact CuSn (bronce) Contact plating Au (gold) Material of contact body PA Material of housing PA Cable data material housing - insulation single lead - single lead structure - conductor resistance - Contacts 4, Female socket, solder termination Normen und Prüfbedingungen siehe Binder Katalog Seite T1-16 oder unter www.binder-connector.de 09 9766 30 04 Product sheet Subminiature connectors Female socket, solder termination Snap-in connectors IP 40 serie 709/719 Pole Article number Date: 2013-07-15 - Page 2 of 2 Product Area 4 09 9766 30 04 Item description Installation instructions / Mounting cutout Normen und Prüfbedingungen siehe Binder Katalog Seite T1-16 oder unter www.binder-connector.de Powered by TCPDF (www.tcpdf.org) 09 9766 30 04
09 9766 30 04 价格&库存
很抱歉,暂时无法提供与“09 9766 30 04”相匹配的价格&库存,您可以联系我们找货
  • 1+55.652871+7.22070
  • 5+50.078875+6.49750
  • 20+44.5919720+5.78560
  • 100+38.93088100+5.05110
库存:184
