76-0532-1011-00008-0200
    BINDER(宾德)
    BINDER - 76-0532-1011-00008-0200 - Sensor Cable, M12 Receptacle, Free End, 8 Positions, 200 mm, 7.9 ...
76-0532-1011-00008-0200 数据手册
Product data sheet Automation technology - sensors and actuators Product description M12-A female panel mount connector, Contacts: 8, not shielded, single wires, IP68, UL, PG9 front mounting Area Order number M12-A series 713 76 0532 1011 00008-0200 Illustration Scale drawing Contact arrangement You can find the assembly instructions on the next page. Technical data General values Notice Connector design Connector locking system Termination Wire gauge (mm) Wire gauge (AWG) Upper limit temperature Lower limit temperature Customs tariff number Packaging Unit Electrical values Please note that, due to the change from the old to the new order number, there may be deviations in the technical specifications. For questions about product details, please use the ‘Contact Customer Service’ form on the right. female panel mount connector screw single wires 0.25 mm² 24 85 °C – 40 °C 85369197 1 Rated current (40 °C) Rated voltage Rated impulse voltage Pollution degree Overvoltage category Insulating material group Insulation resistance EMC compliance Degree of protection Mechanical operation 2 A (UL 1.5 A) 30 V 800 V 3 II III > 10⁸ Ω not shielded IP68 > 100 Mating cycles Material Contact material Contact plating Contact body material Housing material CuSn (bronze) Au (gold) PA Zinc die-cast nickel-plated Cable data Approval 1 UL Date: 2020-01-19 - Page 1 of 3 Product data sheet Automation technology - sensors and actuators Product description M12-A female panel mount connector, Contacts: 8, not shielded, single wires, IP68, UL, PG9 front mounting Area Order number M12-A series 713 76 0532 1011 00008-0200 Assembly instructions / Panel cut-out Date: 2020-01-19 - Page 2 of 3 Powered by TCPDF (www.tcpdf.org) Product data sheet Automation technology - sensors and actuators Product description M12-A female panel mount connector, Contacts: 8, not shielded, single wires, IP68, UL, PG9 front mounting Area Order number M12-A series 713 76 0532 1011 00008-0200 Security notices The connectors are designed for use in plant, control system and electrical equipment. The end user is responsible for checking whether the connectors are suitable for use in other applications. Connectors with degree of protection IP 67 and IP 68 are not suitable for use under water. When used outdoors, the connectors must be separately protected against corrosion. For further information about IP degrees of protection refer to ‘Technical support’ in the Download Centre. Date: 2020-01-19 - Page 3 of 3
76-0532-1011-00008-0200 价格&库存
很抱歉,暂时无法提供与“76-0532-1011-00008-0200”相匹配的价格&库存,您可以联系我们找货
  • 1+146.64766
  • 10+134.88002
库存:44
