99-0771-001-08
99-0771-001-08
    BINDER(宾德)
99-0771-001-08 数据手册
Product data sheet Miniature connectors Product description Bayonet NCC cable connector, Contacts: 8, 4.0 - 6.0 mm, shielding is not possible, solder, IP67 Area Order number Bayonet NCC series 770 99 0771 001 08 Illustration Scale drawing Contact arrangement You can find the component part drawing and assembly instructions on the next page. Technical data General values Connector design Connector locking system Termination Wire gauge (mm) Wire gauge (AWG) Cable outlet Upper limit temperature Lower limit temperature Customs tariff number Packaging Unit Electrical values cable connector Bayonet solder 0.25 mm² 24 4.0 - 6.0 mm 85 °C – 25 °C 85369010 100 Rated current (40 °C) Rated voltage Rated impulse voltage Pollution degree Overvoltage category Insulating material group Insulation resistance EMC compliance Degree of protection Mechanical operation 2A 175 V 1750 V 2 II II ≥ 10¹⁰ Ω shielding is not possible IP67 > 5000 Mating cycles Material Contact material Contact plating Contact body material Housing material CuZn (brass) Au (gold) PA (UL94 HB) PA Date: 2020-01-19 - Page 1 of 3 Product data sheet Miniature connectors Product description Bayonet NCC cable connector, Contacts: 8, 4.0 - 6.0 mm, shielding is not possible, solder, IP67 Area Order number Bayonet NCC series 770 99 0771 001 08 Component part drawing Assembly instructions / Panel cut-out Date: 2020-01-19 - Page 2 of 3 Powered by TCPDF (www.tcpdf.org) Product data sheet Miniature connectors Product description Bayonet NCC cable connector, Contacts: 8, 4.0 - 6.0 mm, shielding is not possible, solder, IP67 Area Order number Bayonet NCC series 770 99 0771 001 08 Security notices The connector must not be connected or separated under load. Non-observance and incorrect use can result in personal injury. The connectors are designed for use in plant, control system and electrical equipment. The end user is responsible for checking whether the connectors are suitable for use in other applications. Connectors used in electrical circuits containing hazardous life parts must only be assembled and used by or under the supervision of persons with the requisite electrotechnical training, taking the applicable regulations and standards into account. Connectors with degree of protection IP 67 and IP 68 are not suitable for use under water. When used outdoors, the connectors must be separately protected against corrosion. For further information about IP degrees of protection refer to ‘Technical support’ in the Download Centre. Date: 2020-01-19 - Page 3 of 3
99-0771-001-08 价格&库存
很抱歉,暂时无法提供与“99-0771-001-08”相匹配的价格&库存,您可以联系我们找货
